thesnake505
posted on 14/8/07 at 07:13 PM |
thaught id try on here, im need of a tps
im in need of a tps for a set of mikuni carbs? cheers the snake
DarrenW
posted on 15/8/07 at 10:34 AM |
I assume the carbs normally have a TPS so you want a bespoke item? or are you retro fitting a TPS to set of carbs that didnt originally come fitted
with one?
thesnake505
posted on 15/8/07 at 03:47 PM |
sorry, its for a set of bike carbs i have fitted to my pinto, there is meant to be a tps there but they didnt come with one! im fitting megajolt and
using a tps for this, however with out one im stuck lol, if it helps the carbs a gsxr 750 from an early 90s bike, cheers snake
DarrenW
posted on 16/8/07 at 03:08 PM |
I had a similar problem trying to suss out how to fit a TPS to a set of ZZR1100 carbs that never originally had one. I have drilled and tapped the end
of the throttle spindle. Will fit a bolt in and then attach to the tps with some rubber hose. Boggs have just made me a manifold with a bracket fitted
to it. When i get it back ill just need to drill the mounting hole and assemble it up.
My MJLJ came from Matt Kimmins so came with a TPS pre-wired onto the wiring loom. Im no expert but looks like a standard pot - has a plastic shaft on
it.
RoadkillUK
posted on 16/8/07 at 04:56 PM |
Get one from a Mondeo and fit it yourself.
I drilled the end of the shaft on the carbs and tapped it with an M4 tap, got an M4 bolt and added a bit of weld, filed it down to fit in the TPS
sensor and made a bracket to fit.
The latest megajolt firmware will allow you to calibrate your TPS sensor.
Come on folks, Locost
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
