Cheffy
posted on 15/8/07 at 08:28 AM |
R380 gearbox - changing from 4WD to 2WD
Is it a straight forward matter to convert a R380 gearbox from 4WD to 2WD?
I have an old LT77 2WD box - can I simply remove the transfer box and replace the end casing with the one off the LT77?
TIA,
Martin.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
TGR-ECOSSE
posted on 15/8/07 at 09:14 AM |
I could be wrong (again) but i think the LT77 and the R380 are not the same casing. Its been a while since i played with the LT77 box.
Fatboy Dave
posted on 15/8/07 at 09:35 AM |
The casings are different, but they can be swapped. The R380 has different mounts to the LT77, which is about the extent of the diferences.
You're going to have to change the tailshaft and selector rods too; it's not a straightforward conversion sadly. Although, with a new R380
2wd at a grand, and a used 4x4 box coming in at about 250, with a scrap LT being 50, it's a cheap way to hybridise.
Dave
Stop the planet, I want to get off
mark chandler
posted on 15/8/07 at 09:59 AM |
Best look for an LDV Van, later ones used these boxes so could donate the bits you need.
Find a V8 one and have the lump, an lt77s is pretty strong anyway.
Regards Mark
Cheffy
posted on 15/8/07 at 01:04 PM |
Hi Guys,
Thanks for the replies.
As I say, I've got an old LT77 but there's a lot of play in the input shaft so is gonna need rebuilding anyway. I was just wondering
whether I would be better off investing in the newer R380 before I start spending money on the old LT.
I can't even identify the LT as it doesn't have the machined face next to the drain plug with a serial number on it like all the others
I've seen. I even e-mailed a picture to the guys at Ashcroft Transmissions who don't know what it is either!
I've worked out the ratio's in each gear by counting the number of input shaft revolutions per one full turn of the output and the
ratio's seem to match that of an early series SD1.
Being something of a gearbox novice I'm just not sure which way to go. I see you can buy rebuild kits for less than a £100. Do you think this
would be the best way to go?
Thanks again,
Mart.
Liam
posted on 15/8/07 at 08:27 PM |
Slight hijack, but i just wondered what happenned to the 4WD plan?? Proving too headache-some?
Good luck with the V8...
Liam
scutter
posted on 16/8/07 at 07:19 AM |
Text message sent.
ATB Dan.
Cheffy
posted on 16/8/07 at 09:43 AM |
Hi Liam,
All was going quite well until I realised I'd miscalculated and that the front prop shaft wanted to go through the side of the sump and the
throw of the crank! I was so tight for space there was just no way to get round it.
If I'm honest I think I was being a little over ambitious and my design skills were not up to the job!
I would have had to rebuild the front end of the chassis completely which would have meant destroying all my work for the inboard front shocks (which
I'm sticking with) and which I'm actually quite chuffed with.
How's yours coming on - not far off now I imagine?
Martin.
[Edited on 16/8/07 by Cheffy]
