New Topic New Reply
Author: Subject: Rad for car engined mk
SyKaTurbo
posted on 16/8/07 at 09:16 AM Reply With Quote
What are you using chaps?
The engine is a 1600 16v Vauxhall engine.
I heard the Nissan Micra rad fits nicely but will this be enough to cool my engine.
donut
posted on 16/8/07 at 09:17 AM Reply With Quote
Should be fine with an electric fan. Mk2 escort also fits after a little fettling.
James
posted on 16/8/07 at 09:30 AM Reply With Quote
Or fit what everyone fits for every engine and use a VW Polo one!
HTH,
James
SyKaTurbo
posted on 16/8/07 at 09:39 AM Reply With Quote
From which year, james?
whitestu
posted on 16/8/07 at 09:50 AM Reply With Quote
should be Polo 1.0 - 94 on.
Part number 65234 on here
link
You might get it cheaper elsewhere though
Stu
oadamo
posted on 16/8/07 at 09:54 AM Reply With Quote
soz to hijack but which fan do you use the polo one.
adam
[Edited on 16/8/07 by oadamo]
whitestu
posted on 16/8/07 at 09:56 AM Reply With Quote
I just used the Sierra one on mine.
It currently has a 1.8 CVH so doesn't need much cooling though.
Stu
posted on 16/8/07 at 10:10 AM Reply With Quote
I used a motorbike fan on mine (Honda blackbird). Works fine. Lighter than a car one too... Can't imagine a 1600 Vaux engine is going to be putting significantly more heat into the coolant than a 1100 Honda engine when it's idling and stationary. When the car's not stationary the fan isn't going to be needed in most set-ups due to the cavernous open front of the 7 design.... And if you're stationary but revving the nuts of the engine your asking for trouble
that price looks good for the Polo rad (cheaper than the GSF price when I bought mine- though they might have come down in price)....
don't forget the fan switch that goes with the rad....
welderman
posted on 16/8/07 at 10:15 AM Reply With Quote
ive got a fiat uon rad, i got two when i build the R1 mini. Not sure if it fits the MK though, not sure on price either.
You can try it though as your a top ender.
Thank's, Joe
I don't stalk people
SyKaTurbo
posted on 16/8/07 at 10:28 AM Reply With Quote
LOL Cheers.
The polo one does seem loads cheaper than the Micra one. Is the micra one metal capped?
I'm on a mad part collecting mission to get everything into the garage before the kit turns up and I still have some free cash. Not doing too bad either. Two and a bit weeks to go!
bob
posted on 16/8/07 at 11:18 AM Reply With Quote
Purchased my polo rad from northern radiators, top service and good price. Rescued attachment rad 004.jpg
SyKaTurbo
posted on 16/8/07 at 01:01 PM Reply With Quote
Looks spot on! Just ordered the Polo one for mine.
What engine is that bob. Are they carbs or throttle bodies your running?
[Edited on 16/8/07 by SyKaTurbo]
matt_claydon
posted on 16/8/07 at 01:51 PM Reply With Quote
That'll be a Zetec on bike carbs
bob
posted on 16/8/07 at 02:21 PM Reply With Quote
Yup matts correct, its an early 1800 phase one with firblade carbs.
I just happened to have a load of black high temp paint so i spruced the old silver top cam cover up, winter mods will be the 2 litre cams and maybe a go at a type 9 gearbox rebuild. (if i get brave)
SyKaTurbo
posted on 16/8/07 at 02:32 PM Reply With Quote
Looks cool.
Mine will be running a 1600 16v Corsa GSI engine on R1 Carbs, Mega Jolt through a type9 on SBD Bellhousing.
Really looking forward to getting stuck into it now
New Topic New Reply
