saigonij
posted on 2/9/07 at 01:04 PM |
pictures of Zetec plumbing please
hi all,
i know how its meant to be plumbed in - im just looking for inspiration on how to actually route the pipes.
so if you have some pictures, please can you let me see, or tell me where to look in your archive.
Ian.
mongrelwestie
posted on 2/9/07 at 01:25 PM |
this is my rough set up, the bottem pipe needs two outlets put in for the header tank and the bottem hose off the stat housing
![](http://i51.photobucket.com/albums/f374/spunky18/DSC07453.jpg)
stevebubs
posted on 2/9/07 at 01:54 PM |
http://gallery.cantcatchme.net/index.php?cat=9
![](http://gallery.cantcatchme.net/albums/userpics/10001/normal_StevePlumbing.jpg)
welshboy
posted on 2/9/07 at 03:27 PM |
hi what is the rad off please ?
mongrelwestie
posted on 2/9/07 at 03:47 PM |
mine was custom made for my chassis, seemed easier then sorcing one
welshboy
posted on 2/9/07 at 04:06 PM |
ok thanks
procomp
posted on 2/9/07 at 04:19 PM |
Hi here is a pic of the way i do the race cars with a zetec. Verry simple and reliable.
cheers matt
![](/galpreviews/N56.jpg) ![Darryls engine bay L/H side](/gallery/N56.jpg) Darryls engine bay L/H side
[/img]
saigonij
posted on 2/9/07 at 05:43 PM |
cheers guys.... keep them coming....
i had ordered a tiger 32mm pipe with 2 15mm take offs - for the bottom hose. I was not gonna use it because of space, but i decided to cut it in half
and take a 4cm chunk out of it.
im really greatful for the pictures.
posted on 2/9/07 at 06:59 PM |
Is that a specially made takeoff from the block Matt and does it have a thermostat in the system? It looks simple enough to be trouble free.
zetec
posted on 2/9/07 at 08:24 PM |
I did the same with the Tiger pipe, also allows you to twist it to give a better angle for the
pipes.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
zetec
posted on 2/9/07 at 08:27 PM |
Use the standard thermostat housing and stat.
UncleFista
posted on 2/9/07 at 08:37 PM |
Here's ours, not quite finished at the time of the pics.
We're using a Micra rad, inlet and outlet are at different sides to the Polo rad.
![](/galpreviews/coolpipebendy.jpg) ![coolant hoses](/gallery/coolpipebendy.jpg) coolant hoses
![](/galpreviews/pipework2.jpg) ![coolant hoses](/gallery/pipework2.jpg) coolant hoses
![](/galpreviews/engview.jpg) ![top view, hoses done](/gallery/engview.jpg) top view, hoses done
Tony Bond / UncleFista
procomp
posted on 3/9/07 at 07:19 AM |
Hi yep just an alloy plate with a 28 mm hole to reduce the flow suficently. Then the runs to the header tank with the input from below then turned up
at 90deg to allow water air seperation.
Then straight down to the rad and out again to the block.
For road use it would pay to incorporate a thermostat in to the system but for race use its not needed.
cheers matt
