Author: Subject: stick-on number plate removal
posted on 19/9/07 at 02:42 PM Reply With Quote
Am I likley to succeed remvoing a stick-on number plate so it is in a good condition to be restuck?
Will using a hair dryer to soften the glue and carefuly peeling off work?
Or it is £ 7 down the drain
Pdlewis
posted on 19/9/07 at 02:46 PM Reply With Quote
I would say getting it off isnt a problem but dont fancey your chances of getting it to stick back on!! sorry
posted on 19/9/07 at 02:48 PM Reply With Quote
I'd imagine the removal process with either be damaging to the number plate or the car- of those two I'd rather trash the plate....
Give it a try but go gently- you might find the adhesive stays on the car- you could use some spray mount to attach the plate the 2nd time if it works. If it's refusing to budge though I'd be tempted to liberally apply soapy water then do the heating trick and go very gently. Ripping off a patch of gelcoat would be bad!!!!
posted on 19/9/07 at 02:51 PM Reply With Quote
^^^ cheers for that; not too worried about the car as I will be painting it but would not be a bunny from happyville if it takes of a chunk of gel coat
My gut feel is the plastic which is ths special reflecting stuff is going to be irreversibly damaged when creased.
twybrow
posted on 19/9/07 at 03:00 PM Reply With Quote
I would be amazed if you rip the gel coat from the surface!
RazMan
posted on 19/9/07 at 03:05 PM Reply With Quote
The reflective vinyl background will probably break up when you try and remove it. It depends on how long it has been exposed to UV light.
Raz
Dangle_kt
posted on 19/9/07 at 03:18 PM Reply With Quote
use an angle grinder, cut round it exactly, then refit it after paint job is done - a couple of wooden batterns holding it on from the underneath.
It'll be reet...
posted on 19/9/07 at 03:47 PM Reply With Quote
I reused my trailer numberplate and it was perfectly alright. Hairdryer and patience and steady pressure and it came off in one piece but I expect it is down to the quality as well.
stevec
posted on 19/9/07 at 04:33 PM Reply With Quote
It'll be reet...
Dutchman
posted on 21/9/07 at 09:09 PM Reply With Quote
try with gasoline , I use it for removing glue from places where vinyl decals where
Tarzan English with foreign accent!
Angel Acevedo
posted on 22/9/07 at 03:23 AM Reply With Quote
cover with masking tape that has had the adhesive weakened slightly, then with a sharp razorblade like you`re skinning a fishgo slow, pushing a little bit more towards the gelcoatand pulling very very gently on the masking tape just to keep the edge away from the razor
