Author: Subject: zx12 help
eccsmk
posted on 19/9/07 at 05:12 PM Reply With Quote
zx12 help
im using the 2004 zx12r loom with toggle switches
im struggling on the lights
should i use
a) on/off/on switch for side and dip and a single on/off for main
b) use on/off/on for dip and main and on/off for side??
thanks in advance
Smartripper
posted on 19/9/07 at 05:19 PM Reply With Quote
Option b is te best, so you can switch on he side lights first,
After that you can go to dim lights or main beam.
Daniel
Paul TigerB6
posted on 19/9/07 at 05:34 PM Reply With Quote
Daniel
Would an Off-On-On switch not be preferable in order to switch between dip and main beams without having to go through the off position??
eccsmk
posted on 19/9/07 at 05:36 PM Reply With Quote
an off/on/on switch would be easier but i already have the others
many thanks people
macspeedy
posted on 19/9/07 at 06:53 PM Reply With Quote
by the way for sva and mot the side lights have to be able to be on without ignition on
eccsmk
posted on 21/9/07 at 06:22 PM Reply With Quote
didnt know that thank you
