New Topic New Reply
Author: Subject: If I had a slightly twisted chassis...
NeilP
posted on 25/9/07 at 09:03 PM Reply With Quote
...As a result of my abrupt kerb visit in August. Is it possible to have it pulled straight without resorting to stripping everything off?
Lower front wishbone took the brunt so if anything is out it will be the lower chassis rail in the engine bay.
I ask 'cos it was enough out when I got the wheels laser aligned to raise the old eyebrows - Mind you I had heard anecdotally that the original Luego Viento jig was a little rustic in it's dimensions...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
nitram38
posted on 25/9/07 at 10:22 PM Reply With Quote
Did you use a good old fashioned tape measure to check your chassis mounting points?
Try checking them diagonally from front to rear. It could be someting other than your chassis.
Allways try lots of things before jumping to expensive conclusions!
wilkingj
posted on 26/9/07 at 08:49 AM Reply With Quote
Try a good old straight edge against the chassis rails. It might give you a clue. As already mentioned, tape measure etc etc.
Does it drive in a straight line (on a level surface), does it pull to one side, or go round left / right corners equally?
Best Regards
Geoff
http://www.v8viento.co.uk
NeilP
posted on 26/9/07 at 09:23 PM Reply With Quote
All been aligned to drive straight but it must be crabbing to do so (by a small amount - say 1 deg).
Haven't done precise geometry checks but that was next on the path - Wondered if others had come across similar problems and what is the concensus? Are there locost straightening techniques?...
mawmaw
posted on 27/9/07 at 06:52 PM Reply With Quote
kit car chassis are never straight (apart from mine 2 years ago) thats why you need adjustability in the suspension, in my view either adjust it uot and forget it or sell the car!
New Topic New Reply
