scutter
posted on 4/10/07 at 10:21 AM |
What's it going to be worth?
I'm sell the Crossflow out of the car, spec as below, how much do you think i should be asking?
1698cc 711M block achieved with a 90 thou over bore, using high compression pistons
Gas flowed stage two cylinder head with a unleaded conversion
Both main and big end are standard sizes, with new standard bolts throughout
New bearings and cam follower’s 3000miles ago during rebuild
Lightened flywheel
1700 supersport ali rocker cover
Filler cap thermostat housing
Westfield alloy short sump, runs level with gearbox bellhousing with internal baffles
Fuelled by dellorto dhla 40’s on a short manifold and fuel pressure regulator / filter and solid state fuel pump.
Ignition by Megajolt, will be supplied with a laptop
Sierra type nine gearbox from a 1.6L, with starter motor and alt.
Also Lolocost manifold and MK can.
Just wondering brfore it gets broken up.
ATB Dan.
[Edited on 4/10/07 by scutter]
posted on 4/10/07 at 10:26 AM |
for the engine and carbs I'll start the bidding at £ 250 cash.
(don't need rocker cover whcih is wroth around £ 30).
it is probably worth a little bit more than that but got to sart somewhere and save on ebay listing/final fees
Deckman001
posted on 4/10/07 at 10:27 AM |
It's probably worth about £700 to a grand, but I doubt you will be offered that, best chance to acheive the true value would probably be to
break the whole sale to components ie engine, box, exhaust and so on
Finaly going Toyota? or bec ?
Jason
posted on 4/10/07 at 10:32 AM |
there is always one who spoils it.
scutter
posted on 4/10/07 at 10:54 AM |
Nothing wrong with it, but i picked up a cheap Zetec, so going to play with megasquirt.
ATB Dan.
D Beddows
posted on 4/10/07 at 11:06 AM |
As one lot I'll bet you wouldn't get much more than about £600 :-( ...... but the cylinder head would probably go for just under £200 on
it's own, the sump £150ish and the carbs and manifold about £200ish again......and you've still got the megajolt/exhaust/block etc to
sell....
If it's a Caterham Supersport rocker cover btw they rarely sell for less than £50 on ebay
[Edited on 4/10/07 by D Beddows]
scutter
posted on 4/10/07 at 11:10 AM |
Looks like i'll be breaking it then, get back from hol's then apart she comes, forgot to add there's a fuel tank as well.
ATB Dan.
trextr7monkey
posted on 4/10/07 at 12:01 PM |
I would be tempted to offer it to the mark 2 escort boys on Oldskool ford and turbosport who look with dewy eyes at these engines and whilst working
tol ocost principles may very wellplace higher values on this as a complete and workable unit to drop into their painstakingly restored shells.
we sold a 1760 x flow for around the £650 mark so it has to be worth more than that with flash carbs, handful of receipts etc
Good luck anyway
Mike
dwyer
posted on 4/10/07 at 12:35 PM |
Crossflow
u2u
Simon
greggors84
posted on 4/10/07 at 06:28 PM |
What happened to the v8 plans Dan?
Chris
The Magnificent 7!
scutter
posted on 4/10/07 at 11:26 PM |
The wife happened to the V8 plans
The Eng. and box are listed on turbosport at the mo for £750.
i'd be willing to knock off another 100 for locost builders.
ATB Dan.
steelydan
posted on 30/10/07 at 04:01 PM |
cheers Dan
should hopefully be in by the end of November, as you didnt get a chance to have a look, this is what it will be going into my daily hack of a 1972
rally prepped mk1 escort
its replacing a 1300xflow that although kicked out a good 80bhp wasnt enough and was starting to get tired, id planned to fit a shorrock supercharger
but its going to be a good few years till thats going to happen, so this will keep me going in the meantime
thanks again
dan
scutter
posted on 30/10/07 at 04:11 PM |
Dan, you're welcome. Get some Lotus Esprit Dellortos and run the super charger through them.
ATB Dan.
Dangle_kt
posted on 30/10/07 at 09:07 PM |
quote: Originally posted by steelydan
cheers Dan
thanks again
dan
YUM!
steelydan
posted on 1/11/07 at 09:52 AM |
ATB Dan.
the thought had crossed my mind , i think you can do it with any dellortos due to everything having seals, plus a supercharger is only say 5-7psi so
you can probably get away with it... it is an attractive option especially with all these cheap mini/eaton chargers about
