Author: Subject: Warning lights
paulmw
posted on 10/10/07 at 09:54 AM Reply With Quote
Warning lights
I have ordered a Savage rear fog light switch which lights up when turned on. Is this sufficiant or do I need another warning light?
The only other warning light I have ordered is for the hand-brake - any others?
posted on 10/10/07 at 09:55 AM Reply With Quote
That's enough. My rear fog light has a tiny 2mm LED and it was deemed sufficient as a warning light.
RazMan
Apart from the usual main beam, hazards, indicators etc?
Raz
posted on 10/10/07 at 09:57 AM Reply With Quote
You need a light to show when the indicator lamps are active (ie hazards). you don't IIRC need separate lights for the L and R indicators- but you can have that if you so desire!!
You'll also need a light to show when your headlights are undipped (ie main beam).
paulmw
posted on 10/10/07 at 10:57 AM Reply With Quote
Cheers guys I now have savage switches for:
Lights - side
Lights - main
Lights - dipped
Horn
Hazards
Fog
Start
And a handbrake warning light and indicator toggle switch
I am using the bike clocks which have indicator lights, etc
So I think that all the bases covered?
