SyKaTurbo
posted on 1/11/07 at 02:31 PM |
Sierra Tripode Location
Lets say some idiot took all his cv's to pieces some time ago but didnt mark the location of the tripodes on his shafts.
Doesn anyone know how they should sit in relation to each other on the ends. Do they line up or maybe site 60degress out? Any ideas.
Thanks in advance
Mr Idiot!
posted on 1/11/07 at 02:45 PM |
hehehe - another idiot like me
I did just the same when I overhauled and fitted new CV boots. I reassebled them without paying any attention to how the ends aligned relative to
each other and they ended up different on both dirveshafts. I also forgot to re-fit one of the plastic spacer/spring seat cups to one of them too
I couldn't be arsed to strip them again and decided it would be OK. So far I've covered 2300 miles this year without any problems at all
and no noise either. I suspect it makes little difference in practice, particularly in view of the overall number of miles you'll be doing in a
7.
Fit them to the car and carry on would be my advice. Unless anything goes wrong of course
posted on 1/11/07 at 06:00 PM |
This is important with universal joints due to the speed variation when running at an angle. By definition CV joints run at constant speed, so
phasing between two joints should be of no consequence.
Humbug
posted on 1/11/07 at 06:15 PM |
Is this idiot related to you?
posted on 1/11/07 at 07:52 PM |
LOL We did the exact same thing on the driveshafts we took apart. Even Ford couldn't offer us any advice about how they should line up, so we
just assembled them as we thought best. Had no problems with them since whatsoever.
Phil
vyperstrype
posted on 1/11/07 at 08:28 PM |
drive shafts
Does it not tell you the alignment in the Haynes workshop manual.
posted on 1/11/07 at 08:34 PM |
Unfortunately not. (I'm gonna look a tw@t if it does........... )
Phil
posted on 5/11/07 at 01:47 PM |
Didn't say in my copy of the Haynes book (hastily flicks through to check) either
saigonij
posted on 5/11/07 at 02:24 PM |
eh, whats this now?
i thought you just shoved the CV joint back on the end of the shaft????
re-aligning whats it now?
