New Topic New Reply
Author: Subject: Does this look right?
paulmw
posted on 12/11/07 at 07:35 PM Reply With Quote
I have bolted up the prop and am not sure if the angles are correct. Will it spin round OK or shake itself to bits? Rescued attachment PICT1752.JPG
stevec
posted on 12/11/07 at 07:37 PM Reply With Quote
No
nib1980
posted on 12/11/07 at 07:41 PM Reply With Quote
NOPE!
the bearing needs to be @ 90 degrees to the prop.
doesnt seem that much angle to me?
bearing is rubber mounted in its housing...
[Edited on 12/11/07 by JoelP]
stevec
posted on 12/11/07 at 07:43 PM Reply With Quote
Here is mine when I had the bike engine in.
Steve.
TGR-ECOSSE
posted on 12/11/07 at 07:45 PM Reply With Quote
Some info on Propshaft Angles Here
From the picture yours doesn't look right!!!!
designer
posted on 12/11/07 at 07:52 PM Reply With Quote
Any propshaft angles should not add up to more than 7.
paulmw
posted on 12/11/07 at 07:55 PM Reply With Quote
Cheers.
So should I make up some new angled spacers so that the prop closest to the engine is at 90 degrees to the bearing?
To add: MK had my engine when they made the cradle so must have known the positions. They also made the spacers and the prop. So just wondering why they would go to so much trouble making it wrong
[Edited on 12/11/07 by paulmw]
posted on 12/11/07 at 08:30 PM Reply With Quote
we're all yapping up different trees here! Theres nowt wrong with the propshaft angles, its nearly straight.
If you are worried about the angle of the bearing housing, just straighten it up. I bolted mine to the bottom of my tunnel so it was nearly straight, rather than to the slanted side of the tunnel. You may have to mess about drilling new holes and making different spacers though. Id leave it unless the rubber is at the limit of its flex. There are no moving parts here anyway, since its a fixed diff and a fixed engine.
Optimum Balance Products
posted on 13/11/07 at 09:27 PM Reply With Quote
I agree, get the bearing as straight as you can. Other wise it will vibrate.
Optimum Balance Products Ltd specialise in floor mounted and top mounted pedal boxes. We also manufacture many other products and can under take one off alloy fuel tanks or other design projects. Please contact us via email to sales@obpltd.com or have a look at our fantastic ecommerce web site www.obpltd.com
Thank you for your time.
All the best,
Obp Ltd.
TimC
posted on 14/11/07 at 10:40 AM Reply With Quote
Different kit, similar problem. Angled shims sorted me out.
New Topic New Reply
