Sporty
posted on 13/11/07 at 10:08 AM |
Spigot Bearing Location
Got all my parts sorted for mating the type 9 to the zetec. Quick question before I do something I'm not going to be able to reverse.
I assume that the spiggot bearing goes in the centre of the Flywheel, its a tight fit obviously but just want to check before I start hitting it with
a big hammer.
Ian
whitestu
posted on 13/11/07 at 10:13 AM |
It goes into a recess in the end of the crank, accessed through the hole in the flywheel.
It is fairly tight.
Mine needed a gentle ish tap to go in.
Stu
Sporty
posted on 13/11/07 at 10:56 AM |
Thanks, I take it the flywheel needs to come off as the hole in it is too small to get the bearing through comfortably, or am I missing something.
Ian
Werner Van Loock
posted on 13/11/07 at 11:13 AM |
The bearing goes in the middle hole. with or without flywheel, doesn't matter, what does matter is without clutch. Maybe that's what you
meant?
http://www.clubstylus.be
westcost1
posted on 13/11/07 at 12:34 PM |
yes just bang it in![](/images//smilies/bigsmile.gif)
Paul (Notts)
posted on 13/11/07 at 06:19 PM |
to fit the spiggot bearing on my rover v8 crank I left it in a plastic food bag in the frezzer for 4 days so that It cooled down and contracted - It
then was a simple tap in and as it warmed up a very tight fit.
Paul
NS Dev
posted on 16/11/07 at 02:30 PM |
Tap it in, goes in no bother, but make sure its the right way round, most have a seal lip on the clutch side
