Author: Subject: Fuel Swirl Pot
keith2lp
posted on 20/11/07 at 01:11 PM Reply With Quote
Fuel Swirl Pot
Hi
As I am upgrading to a duratec from a Pinto and I don,t have a swirl pot in my fuel system I need to add one.
I plane to run a low pressure pump to the swirl pot then high pressure to the injectors & then return to the swirl pot. I will also run a return from the swirl pot to the tank.
Can the swirl pot be located in the engine bay or does it need to be close to the tank.
Keith
[Edited on 20/11/07 by keith2lp]
twybrow
posted on 20/11/07 at 01:15 PM Reply With Quote
Why is this posted in BEC sec tion? Might do better in the EFI section.
I cant see why it would make any difference as to where you put the swirl pot. Ideally I would think you would have it as close to the tank for ease of plumbing/wiring.
ned
posted on 20/11/07 at 01:18 PM Reply With Quote
low pressure pumps pulls better and a higher pressure pumps pushes better. I fitted all mine in the boot near the tank - pics in my archive.
Ned.
beware, I've got yellow skin
RazMan
posted on 20/11/07 at 01:24 PM Reply With Quote
Have you thought about a Range Rover pump assembly? Pump, swirl pot and sender all in one.
Raz
Paul TigerB6
posted on 20/11/07 at 01:41 PM Reply With Quote
Is this the one Raz?? http://cgi.ebay.co.uk/Range-Rover-EFi-Discovery-fuel-pump-injection-petrol_W0QQitemZ160180109175QQihZ006QQcategoryZ31348QQssPageNameZWDVWQQrdZ1QQcmdZV iewItem
I have been looking at a suitable pump for a ZX12R engine so would this be suitable for a bike engine??
Also, any specifications on this part anyone - fuel level sender spec, dimensions etc etc
Paul
Edited to add the link that vanished!!! Doh
[Edited on 20/11/07 by Paul TigerB6]
robertst
posted on 20/11/07 at 01:53 PM Reply With Quote
does that mean you won't be needing the pinto exhaust? i would be very much interested in it...
Tom
RazMan
The Discovery V8 pump assembly is telescopic and mounts in the top surface of the tank - you will need to fabricate a circular mounting ring. It adjusts itself to the depth of the tank and the pickup always remains on the bottom - unfortunately I havent got the measurements to hand but I would estimate that the depth can be between 250-300mm.
[Edited on 20-11-07 by RazMan] Rescued attachment Land Rover Discovery 4.0L V8 fuel pump assembly.jpg
Raz
matt_claydon
posted on 20/11/07 at 02:36 PM Reply With Quote
That thing looks amazing, wish I'd known about them when I did my EFI install! I presume the bit at the bottom is the swirl pot and is isolated from the fluid / air in the main tank?
RazMan
posted on 20/11/07 at 02:53 PM Reply With Quote
Yep, nice and easy to install - even the sender too.
Raz
MikeR
posted on 20/11/07 at 04:21 PM Reply With Quote
Also fitted to MGF's ......... and i think other MG's. Mate used to work for the company that designed & made them. When they cleared out the display cabinet it ended up in my garage instead of the bin (ready for the one day EFI project).
Paul TigerB6
posted on 23/11/07 at 06:25 PM Reply With Quote
Does anyone know what the specification is of the sender on this unit at all (ie what ohms is the sender)??
RazMan
posted on 23/11/07 at 11:22 PM Reply With Quote
I would imagine that it will be compatable with the majority of electronic dash modules. I just connected it to my Evodash with no problems anyway.
Raz
MikeR
posted on 27/11/07 at 09:26 PM Reply With Quote
keep reminding me - one day i'll get back into the garage (then i've got to move all sorts of rubbish to get into the attic space, then find the EFI box then i'll measure the resistance)
(ie don't hold your breath and keep reminding me )
