Author: Subject: Zetec Water Pump Rotation
Dave Bailey
posted on 22/11/07 at 06:56 PM Reply With Quote
Hi!,
I think I read somewhere that the phase 3 zetec water pump runs anticlockwise and yet the earlier zetec ran clockwise. Anyone know if this is the case plus which pump I need to buy to get the pump to run clockwise if in fact I have it the correct way round?
Dave B
r1_pete
posted on 22/11/07 at 07:05 PM Reply With Quote
Yep, my phase 3 1.8 ex Focus motor, has the pump spining anti clock, I dont think there is a clockwise version for the 3, its totally different to the phase 1 & 2, but hope someone proves me wrong it would mean I can simplify my belt arrangement.
Rgds.
Pete.
jonno
posted on 22/11/07 at 07:14 PM Reply With Quote
So what way does the 1.8 from a mondeo run ?...thought i was ok with the 1.8 !, so might need one from a 1.8 escort
r1_pete
posted on 22/11/07 at 07:16 PM Reply With Quote
Escort zetec is phase 1 & 2, Phase 3 is completely different, the water pump is offset to the right when you're facing the engine:
If the Escort impeller will fit the Ph 3, we might be in with a shout at CW rotation.
[Edited on 22/11/07 by r1_pete] Rescued attachment zetec.jpg
theconrodkid
posted on 22/11/07 at 07:18 PM Reply With Quote
depends on weather the car had power steering or not,you need the non pas pump,as for the blick top i believe you can get the right direction one from the good old us of a
who cares who wins
pass the pork pies
Dusty
posted on 22/11/07 at 07:33 PM Reply With Quote
All 2l mondeo zetecs pumps are designed to run anticlockwise viewed from in front of the engine(apart from the usa one). 1.8 silvertop escort water pumps are designed to run clockwise and bolt straight on to 2l silvertops. Get the 1.8's ribbed pulley as well. Phase 3 or blacktop zetecs can use the usa pump or more usually an idler-pulley fitted above and to the right (viewed from in front of the engine) of the pump pulley so the pump can be driven anticlockwise from the back of the belt.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=blacktop.jpg
[Edited on 23/11/07 by Dusty]
Werner Van Loock
posted on 22/11/07 at 07:40 PM Reply With Quote
Silvertop/phase1/2:
-escort1.6/1.8: clockwise metal impeller
-mondeo1.6/1.8/2.0: anti clockwise plastic impeller interchangeable with the escort unit
Blacktop/phase3: anti-clockwise and complete different pump then the silvertop, so not interchangeable
You'll need a idler pulley to get this one working.
Maybe that in the US a different one exists, but certainly not in the EU.
Here's a example on how to do it on a blacktop/phase3 zetec:
source: www.gtmlibra.nl
http://www.clubstylus.be
madteg
posted on 22/11/07 at 08:22 PM Reply With Quote
black top
Just to let you all know my engine is a black top with a silver top sump,oil pump, oil pick up,cam cover,inlet/exhaust manifolds and a home made idler bearing. So they are not so different. The main difference is that the cam followers are solid shimmed,as the hydralic followers tend to fail at high revs, hope this has helped.
Dave Bailey
posted on 22/11/07 at 09:39 PM Reply With Quote
Which way does the crank pulley rotate on a phase three or I suppose any zetec?
clockwise?
r1_pete
posted on 22/11/07 at 09:53 PM Reply With Quote
Now I'm really interested, the Ph2 sump can be fitted? if I can get rid of the intermediate sump I wouldn't need to mod the suspension cross member on the MGB, any more details / pics on what you've done?
Rgds.
Pete.
jonno
posted on 22/11/07 at 10:57 PM Reply With Quote
Any idea if this is ok for a 1.8 mondeo (was a K plate, silver top) ??
ebay Item number: 200174030631
and i thought i was getting somewhere !!
[Edited on 22/11/07 by jonno]
having fun on a budget
Dusty
posted on 23/11/07 at 12:25 AM Reply With Quote
That water pump converts mondeo zetecs to kit car friendly rotation. You will need the pulley as well. The 'wrong' rotation mondeo/focus pumps have an outlet that angles down about 30 degrees and about 20 degrees back toward the flywheel end of the engine. The correct escort pump outlet angles down about 30 deg but at right angles to the side of the engine. ie parallel to the front face of the engine.
Werner, doesn't the arrangement you show turn the alternator in the 'wrong' direction? Does that work OK or do you have to fit a honda alternator or something.
djtom
posted on 23/11/07 at 12:50 AM Reply With Quote
The water pump still works quite happily when turned in the wrong direction as it is a centrifugal pump, not a screw pump, so don't worry too much about it. It's probably slightly less effective, but mine is running the wrong way and still managing to keep a ~200bhp silvertop Zetec turbo cool with seeming ease.
Lots of people on the Westfield forum are running them the wrong way with no ill-effects as well.
Tom
Werner Van Loock
posted on 23/11/07 at 07:21 AM Reply With Quote
I think that it's a daihatsu charade alternator. It's not mine you know, just a picture i came across searching the net for zetec info. And for most alternators direction doesn't matter as it's a AC generator with a rectifier mounted to it to make it around 14Vdc
