posted on 22/11/07 at 09:33 PM |
New personal best average tin top MPG
In response to the ridiculous and still rising cost of diesel I set myelf a challenge today to see what I MPG I could achieve.....
Stockport to Winchester = 223 miles
Average speed = Ø51 mph
Average mpg =Ø69.4 mpg (see pic below)
This took immense patience and restraint, but I have to say is sadly rewarding
Seat Leon Cupra TDI PD150
81k miles
04 plate
1500rpm gear changes and max rpm
55mph max
slip-streaming HGVs
no braking (at all)
no air con
69.4 MPG
[Edited on 22/11/07 by nick205]
posted on 22/11/07 at 09:34 PM |
my van has got 22mpg over the last 17k!
zilspeed
posted on 22/11/07 at 09:37 PM |
The not braking bit is the most important I find. It means you slow down early and don't chuck fuel away.
Moorron
posted on 22/11/07 at 09:38 PM |
yeh i was happy with my improved 16mpg over my normal 14mpg in my v8.
i uni mate who did car testing around conventry Ring road told me that its better to floor it to your cruising speed as the engine is more efficient
at WOT and dont dip the clutch when coasting down a hill. he said it made a big difference.
i just floor it all the time. .........14mpg no wonder lol
Sorry about my spelling, im an engineer and only work in numbers.
MkIndy7
posted on 22/11/07 at 09:42 PM |
Leeds to Brixton,
a steady 70ish mph
and 55 MPG
And that was just taking it steady and not particularly trying.
In an Opel Corsa Mk1 with a 2L Red Top engine, Just wish I had the 6 speed F28 Gearbox as well!
P.S who needs Diesel
[Edited on 22/11/07 by MkIndy7]
Simon
posted on 22/11/07 at 09:47 PM |
When we were running in the wifes Rover BRM we achieved 62mpg (1.8 VVC petrol) - same sort of driving, but 3k limit, max 60mpg
The official figs for the Rover 25 diesel were over 70 mpg, 6 years ago - better than the Toyota Connedubrid. So beginning to wish I had one
Simon
whitestu
posted on 22/11/07 at 09:51 PM |
I managed 22mpg in my passat 130 tdi yesterday.
Driving in central london is great!
Stu
bigandy
posted on 22/11/07 at 10:03 PM |
My record driving to work and back (60 miles in total) is an indicated 72.1MPG. That was driving at around 60mph for the best part of the journey,
accelerating fairly gently and not really braking.
Oh, and that was in a Skoda Fabia vRS (130bhp diesel).
The strange thing is, that if I drive normally (70mph.. ish) and use my usual heavy right foot, I still get an indicated MPG of 65 ish...
Dammit! Too many decisions....
the_fbi
posted on 22/11/07 at 10:17 PM |
F18 Wide is better than the F28
Or you can change the 5th in a F20 to make it better than the F28.
Although unless your cruise speed is high enough to be at a decent rev range you'd probably find it annoying (or just slow) with an XE and such
a high 5th/6th.
F28 is 26mph/1000rpm with standard wheels/tyres which isn't actually that special.
andyharding
posted on 22/11/07 at 10:20 PM |
I've been making 2000RPM changes/max revs and taking it really easy on my last tank full and managed 27.8MPG. Wish I had a diseasal now.
[Edited on 22/11/07 by andyharding]
mark chandler
posted on 22/11/07 at 10:26 PM |
best I got a few years ago in a v12 XJS was 19mpg, usually it was 12mpg, or worse than that 9mpg if I popped into town.
The answer is, take a jag engine out !
MkIndy7
posted on 22/11/07 at 10:30 PM |
What can you change the 5th Gear in the F20 to, to make it better for cruising?
70 MPH is a smidge over 3K and it'd be nice to be under hence thinking a F28 box would be better (but chassis mods needed) And it'd shut
the induction/exhaust up a little by keeping it under 3k
It pulls well enough in 5th as its a lighter car than the engines intended for and can pull max rev's in 5th!
posted on 22/11/07 at 10:34 PM |
Once managed to get 30.5 MPG out of my old Rover 3500S , but that was driving as if I had an egg under the throttle pedal . Who said v8s are thirsty.
Mind you "normal" driving was about 15MPG
takumi
posted on 22/11/07 at 10:45 PM |
I loved playing this game..
My best was 647miles on 1 tank of diesel (fill to fill) in my '51 plate 106 Diesel. I calculated it to be over 70mpg.
This was commuting from Woodbridge to Colchester, including hitting rush hour traffic. Driving slowly on a very busy dual carrageway is quite
scary..!
Diesel Rules!
[Edited on 22-11-07 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
the_fbi
posted on 22/11/07 at 10:46 PM |
You'll need to wait till this
link comes back online, or message "Mark T" on Migweb.
Its an F18W's 5th cluster into an F20 basically.
MkIndy7
posted on 22/11/07 at 10:55 PM |
Thanks alot.. just bookmarked the link, will just have to prey it comes back online.
I might loose the reputed 140 ish top speed but it'd be worth it to quieten it down on the motorway.
posted on 23/11/07 at 12:07 AM |
In my Octavia 2.0 TDI 140 I regularly get 60 mpg if I take it steady. Funnily enough I was using the idea of as soon as I came to stop (in traffic)
I'd switch off the engine. The mpg shout up!
Trouble is when I actually measure the mpg using actual fuel it works out to usually 4mpg LESS than the shown mpg. Still at 56mpg actual I think thats
pretty good.
Getting a Leon FR 170 next week, see what that does??? Shoud be fun...
smart51
posted on 23/11/07 at 08:04 AM |
I did 95 MPG in my first smart by doing a steady 50 along the M5. It was the longest journey I ever made. That was shortly after I won the smart
club MPG marathon (cross country) at 61 MPG.
Don't go too fast and dont brake are the key factors, as well as pumping your tyres up. Don't shift up too soon or too early either, keep
your petrol engine between 2000 and 3000 RPM.
DaveFJ
posted on 23/11/07 at 08:47 AM |
My new Civic diesel (you know, the one they market as the best diesel in the world!) usually returns about 40mpg
If I take it easy on a motorway run I can get up near 50mpg....
I guess that economy isn't one of the things that make it the best!
Dave
gingerprince
posted on 23/11/07 at 09:15 AM |
Sorry I crashed into that car officer, you see, I was saving fuel
posted on 23/11/07 at 09:26 AM |
pretty good.
Nearly chose one of these myself, but then found out we have twins on the way (+ a 2 yr old) so had to change to a Passat estate
I reckon you'll easily get the same or better out of it though - if driving carefully
bimbleuk
posted on 23/11/07 at 10:02 AM |
I did have a search on driving economically when I bought my diesel initially. Some Swedish research basically recommeneded using approx 80% of engine
power to accelerate your car to crusing speed and keep there through observation/anticipation not braking etc.
I changed my everyday driving using the above and limiting my RPM to 3000RPM and using torque not power like I would in a petrol (The audi engines
will make power up to 4200RPM). On my everyday commmute on mixed roads went from 43mpg to 47mpg and 50+ on long journeys.
I don't nanny the car along either I just carry speed thourgh the corners and brake late and harder. I didn't realise the until recently
thermostat was running the temps a little low and there was an intermittent fault on the MAF so maybe that'll improve futher.
locoboy
posted on 23/11/07 at 10:08 AM |
I drive my 406 2.1TD estate like a grandad most of the time.
I donot go over 3K rpm except once a month just to check it will still do it and its surprising how well it goes above 3K
I return a steady 42 mpg measured by miles and actual fuel as i dont have a mpg computer.
I have only managed a max of 50mph on a motorway journey, my everyday drive is all B roads, so not much difference really.
Locoboy
posted on 23/11/07 at 10:09 AM |
After watching top gear drive the diesel audi from london to aberdeen and back on 1 tank I had a go in my 850 T5 from Birmingham to London.
Typical motorway mpg is in region of 25 but by not braking, gently acceleration and limiting top speed to about 65, I go 36 mpg!!
that is an improevmetn of almost 50% (rounded up to the nearest 50) ... but not a nice way to drive.
DarrenW
posted on 23/11/07 at 10:53 AM |
Ive seen 66mpg on a run to bristol at around 70 ish mph before, strangely i struggle to maintain it on way back home. Is the North higher than the
South????????????
320D tourer BMW (150BHP version)
