stuart_g
posted on 23/11/07 at 09:32 AM |
Suspension bush lubricant
What type of lubricant do you use when assembling suspension bushes into wishbones and for the crush tube.
I seem to remember someone not recommending copper slip.
mookaloid
posted on 23/11/07 at 10:05 AM |
I used red silicone based grease - usually used for brake components and won't attack rubber/plastic.
Copaslip is oil based and might damage the plastic or cause it to swell or deteriorate.
I think........
Mark
GeoffT
posted on 23/11/07 at 10:48 AM |
I recently bought some new urethane bushes from Wisbech Engineering and noticed that they also recommend silicone grease. My original bushes, on which
I *think* I used normal bearing grease, are all now creaking madly.....
[Edited on 23/11/07 by GeoffT]
pewe
posted on 23/11/07 at 11:48 AM |
If it's just for assembly a quick squirt of Armorall works for me. Cheers, Pewe
ditchlewis
posted on 23/11/07 at 03:39 PM |
mk advised me to use a silicon lubricant. i bought some in a spray can.
ditch
donut
posted on 23/11/07 at 04:37 PM |
i used red plastic greese.works a treat but gets everywhere!
posted on 23/11/07 at 05:13 PM |
Copaslip is not a lubricant it's an anti-seize compound.
posted on 23/11/07 at 06:31 PM |
Used rubber grease when I did mine. Make sure the crush tubes are not too short like mine and a few others were! If the arms are tight when fitted you
have a problem , found the easiest way to test was to nip each assembled bush/crush tube in a vice and rotate the arm.
