Author: Subject: Whats this Megasquirt error?
Big Daz
posted on 25/11/07 at 09:21 PM Reply With Quote
Ok, following on from the previous sparking issue post,
I have now discovered an error on starting up Megatune:
Contorller code does not match MSnS-extra.ini
Expected MSI/Extra format 029y3 xxx (found in ini file)
Received MSnS-extra format 029q (from controller)
Table corruption may occur this is usually a very seroius problem!!
Doesnt sound good does it?
Car cranks and gives a few pops on relese of starter button, sound like timing is MILES out to me.
Anyone help?
Anyone got a suitable format map for 2.0 zetec with dual coil drivers & throttle bodies.
Daz
paulf
posted on 25/11/07 at 09:26 PM Reply With Quote
You need to go into megasquirt config and select the correct version of the firmware installed in your ECU.There is a drop down menu that you select and then save the version in.You will need the megasquirt and spark extra settings.
Paul.
Big Daz
posted on 26/11/07 at 11:02 AM Reply With Quote
So the Megasquirt has on older version of code than the current map?
And I change this from megatune?
Sorry not very up to speed with this yet...
Daz
