Author: Subject: Electric Gear shift on BEC
madrallysport
posted on 5/12/07 at 12:57 PM Reply With Quote
Has anyone made a system like this, at a budget, or is using one at the minute? Are there any of these systems avalible on the market?
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
posted on 5/12/07 at 01:02 PM Reply With Quote
Pathfinder
Phil
angus.d
posted on 5/12/07 at 01:06 PM Reply With Quote
I would be interested in the same thing. I had thought of some kind of preferably light weight flywheel/ring gear bolted either just in front of the diff or somehow mounted behind the bike engine. This could use a car starter motor to engage for reverse with perhaps a solenoid acting from the neutral light switch to deactivate if the bike engine/box had been left in gear.
Haven't done much searching yet
Angus
angus.d
posted on 5/12/07 at 01:08 PM Reply With Quote
Sorry
I see you were talking about a gear shifter not an electric BEC reverse !
Angus
gingerprince
posted on 5/12/07 at 01:14 PM Reply With Quote
Keep an eye on e-bay. I just picked up a full kit for 150 quid, unused. They don't come along that often (last one I just missed out on was a couple of months ago) but if you're not in a rush you can pick them up considerably cheaper than new. Usually sold from people who've bought bikes that had been modified for a disabled rider.
[Edited on 5/12/07 by gingerprince]
Ricks-9r
posted on 5/12/07 at 03:29 PM Reply With Quote
http://biketransplant.tripod.com/parts.htm
DIY system
TimC
posted on 5/12/07 at 05:05 PM Reply With Quote
Using a Kliktronic - bought 2nd-hand off a forum member. As has been said, keep an eye-out on eBay.
jono_misfit
posted on 5/12/07 at 11:12 PM Reply With Quote
ive just designed the controller for one of these as my final year uni project.
It does shifting based on gear barrel position, with re shifting attempts, spark cut, throttle blips and automatic neutral shuffle.
Im hopefully building a pre-production version at the start of the new year. Designed as a favour to my friend who builds hillclimb cars.
The controllers fairly straight forward to design using a microcontroller and interface circuits.
The bit im not looking forward to is writting the interface software to allow users to set things for their specific engine and gearbox.
