Author: Subject: Stupid Question: whats wrong with different engine mount rubbers
davidosullivan
posted on 12/12/07 at 01:40 PM Reply With Quote
Ok, I was reading a thread the other day that suggested buying new engine mount rubbers before measuring up to make the engine mounts.... fair point!
So my stupid question. is there any reason why I shouldn't buy different mounts to the originals?
I cant see an issue, unless there is some thing about shock absorbance/weight of engine or something?
Having said all that I'm using a 1.6 pinto out of a 70s capri so I expect the factors will have some anyway.
D
Mr Whippy
posted on 12/12/07 at 01:56 PM Reply With Quote
I have used transit diesel mounts on my falcons pinto in the past. Their quite large but the rubber is so soft you can dig your nails into it. Can't feel a thing from the engine even with a mild race cam.
[Edited on 12/12/07 by Mr Whippy]
mark chandler
posted on 12/12/07 at 02:33 PM Reply With Quote
No reason not to use other things, I used panard rod bushes on mine, gives a captive mount in case of bush failure.
davidosullivan
posted on 12/12/07 at 03:04 PM Reply With Quote
Panhard Rod Bushes? you mean the chassis end of your mounts hold the bush, and then it has a u-bracket??
As with all threads these days... any photos would be great.
I'll be making the whole mounts (probably over Christmas) so just checking out the options.
Cheers.
... looked through your archive and couldnt see any
[Edited on 12/12/07 by davidosullivan]
posted on 12/12/07 at 03:07 PM Reply With Quote
MK and others use the big square landrover engine mounts with a threaded stud either side. Cheap, almost solid (which stops the engine moving around to much) and dead easy to design around.
Mr Whippy
posted on 12/12/07 at 03:33 PM Reply With Quote
really there's no correct answer just depends on what your after but certainly try other mounts, the ford ones were rather basic.
posted on 12/12/07 at 03:45 PM Reply With Quote
Land-Rover ones are very cheap and a lot stiffer
Mr Whippy
posted on 12/12/07 at 03:57 PM Reply With Quote
No softers better.…...yes! It’s the softer v harder war!, time for a blazing rant!!!
jacko
posted on 12/12/07 at 05:36 PM Reply With Quote
Hi have a look in my photo archives under engine stabiliser mounting it will help you
Jacko
r1_pete
posted on 12/12/07 at 06:11 PM Reply With Quote
One thing to bear in mind, if you have long engine mounts, i.e. sticking out a long way from the block, use softer rubbers, hard rubbers can lead to the mounts fracturing due to the tourque of the engine needing to flex the mounts on acceleration / deceleration.
Vice versa, soft rubbers close to the engine centre can lead to too much engine movement.
Again no real right or wrong just needs a balance.
Rgds.
Pete.
UncleFista
posted on 12/12/07 at 07:57 PM Reply With Quote
Another "I used Land-Rover diesel ones too" post
They allow almost no engine movement at all I like to feel the engine through the chassis
Tony Bond / UncleFista
davidosullivan
posted on 14/12/07 at 03:18 PM Reply With Quote
soft or hard (ooh er!)
So long mounts = soft rubbers and short mounts = hard rubbers.
As I currently only have the capri ones to go on, does anyone know if they're considered hard or soft?
They're a cylindrical rubber with a stud on each side.
a bit like this... linky linkerson but without the metal engine mounts
t.j.
posted on 14/12/07 at 05:29 PM Reply With Quote
I use the original mountings also.
The original take a lot of space and are mounted on an angle.
So your exhaust and your steering-shaft could cause problems.
Good luck, don't be scared to walk an other path.
Look into my photo-archive...
[Edited on 14/12/07 by t.j.]
posted on 15/12/07 at 12:58 PM Reply With Quote
Having the engine and gearbox flopping around isn't a great idea in a locost with limited clearances!
Soft engine mounts are perfect for production cars where you want as much vibration absorbed as possible. On something like a Locost you want a nice direct link between the road and the engine.
