Iain Campbell
posted on 9/10/03 at 10:27 AM |
remote gear lever info needed for race car
Hi..
I need info on remote gear lever, for x/flow 4 speed box, I need to bring it back 5"-6" nearer the driver, what do I need? or where to buy
something..
thanks..
macspeedy
posted on 9/10/03 at 11:47 AM |
There are 2 ways, 1st you have a similar pole 5-6 inches further back working in paralell to the stick in the box connected with a horizontal pole,
doesn't look very attractive the second is neater but requires you to beable to make parts on a lathe or buy them, heres the website with pics
this is for type 9 not 4 speed, i am not sure what the difference at the gear selector but i am sure a simlar idea would work.
http://freespace.virgin.net/d.w.jenkins/gear_extend.htm
also
http://www.geocities.com/drusling/engine_main.htm#boxoverhaul
hope these are of some help
posted on 9/10/03 at 12:01 PM |
I was thinking about blowing my own trumpet, but I wasn't sure what the back end of a 4-speed looked like! If it's the same as the
5-speed then it should work OK.
cheers,
Iain Campbell
posted on 9/10/03 at 06:57 PM |
remote problem on 4 speed
Hi.
The 4 speed lever setup is different in a lot of ways to the 5 speed, I've looked up the web pages and saw how the T9 remote worked and then on
mine, it will not do..I might have to change the box for a T9 and sell the prop and box and quickshift... :-( I was hoping to keep the 4 speed for
weight reasons, and on the track or Hillclimb I never would need 4th let alone 5th..I was hoping someone would have the remote sitting in the back of
the garage... building kits is never easy..
Iain Campbell
posted on 10/10/03 at 09:20 PM |
Reverse gear operation
Hi
How does the remote setup effect reverse gear operation? what with the need to push down and over to the left?
Thanks.
