Author: Subject: lifting eyes on ecotec?
blakep82
posted on 19/12/07 at 10:53 PM Reply With Quote
does the ecotec have lifing eyes? i can't see any on the engine! does vauxhall sell them? i'm a bit wary of the way i'm lifting just now, with a nylon strap underneath. its not very well balanced...
________________________
muzchap
posted on 20/12/07 at 12:17 AM Reply With Quote
Lifting my C20LET in and out (several times) we just used the bolts in the head - with some chain and strong bolts.
If you use 4 bolts and pieces of chain its much easier
I done this 4 times twice out twice in - in an Astra Mk3 Turbo - worked fine.
M
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
rayroni
posted on 20/12/07 at 11:36 AM Reply With Quote
Mine does (1.4) - bolt on ones. One on exhaust stud of number 4, the other somewhere near inlet number 1. I do suspect there is meant to be another one near the ECU/inlet 4 but not sure.
speedyxjs
posted on 20/12/07 at 01:39 PM Reply With Quote
Pre V8/6 jag engines had eyes that bolt in place of the exhaust manifold but we just put plenty of strong rope roundump and bellhousing.
