Author: Subject: Can you buy blades for a mitre saw so it can cut metal?
Dangle_kt
posted on 28/12/07 at 05:44 PM Reply With Quote
brother in law has old mitre saw rotting in his garage. He's moved away for a few years and was wondering if I could use it as a chop saw for metal.
I'm struglling to find a metal cutting blade though as I dont know the proper name for it or where to purchase.
Is this plauseable?
Marlon
posted on 28/12/07 at 05:51 PM Reply With Quote
can't think of the name of them off hand but yes you can get bldes that cut both steel and ally if your saw is big and hard enough, we use them at work.
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
Volvorsport
posted on 28/12/07 at 05:52 PM Reply With Quote
Rage ! , i think thats what theyre called , £179 is what the mitres saw csts .
www.evolutionpowertools.com
www.dbsmotorsport.co.uk
getting dirty under a bus
Dangle_kt
posted on 28/12/07 at 05:56 PM Reply With Quote
I've got the saw, I just need blades for metal.
Are they blades or discs? Do you use oil to lube it or just chop through?
Rhys aka Celtic Tools
posted on 28/12/07 at 06:01 PM Reply With Quote
Is this plauseable?
Hi Dangle_kt can you tell me the size of the blade overall and the size of the bore (the hole in the middle of the blade)
and I will have a look my shop for one for you.
ta
Rhys
For all your tool needs contact Rhys @ Celtic Tools 02920 619137
www.stores.ebay.co.uk/celtic-tools
Big discount for all my fellow locost builders
Dangle_kt
posted on 28/12/07 at 06:16 PM Reply With Quote
Is this plauseable?
ta
Rhys
cheers mate, I havn't got the sizes to hand. I'm over there tomorrow so will u2u you then. I do know that it doesn't currently have a blade in there. So i'll see if I can figure it out by looking out how it mounts etc.
Cheers mate.
posted on 28/12/07 at 06:28 PM Reply With Quote
the rage blade is like a normal blade but with teeth facing both ways, probably made of something tough. You can also get large abrasive discs like from a grinder.
heres the rage one:
http://www.screwfix.com/prods/57380/Blades/TCT-Circular-Saw-Blades/Evolution-TCT-Saw-Blades/Evolution-Multi-Purpose-Blade-355mm
or this abrasive one:
http://www.screwfix.com/prods/32164/Blades/Metal-Cutting-Discs/DeWalt-Cut-Off-Blade-355-x-25-4mm-A30TBF
delboy
posted on 28/12/07 at 06:37 PM Reply With Quote
Please be very carefull fitting a metal cutting bade in your mitre saw. The rage ones do work, however, the speed of the saw is much less than your standard saw , check the spec and you'll see. I'd be concerned that a faster roatating saw might cause problems with the blade technology.
Dangle_kt
posted on 28/12/07 at 07:10 PM Reply With Quote
what about using the abrasive one joel mentioned.
delboy
posted on 28/12/07 at 07:49 PM Reply With Quote
Can't say on abrasive type one, only mentioned the other as my brother, whose an ironmonger and sells such things warned me off when I asked about doing the same. Having looked into the rage technology saws, I found out that what he had said was correct. I just didn't want to see someone else make a mistake like I was about to.
niceperson709
posted on 28/12/07 at 08:52 PM Reply With Quote
i used the abrasive cutting discs in a cheap mitre saw and It worked fine but as the disc wore down it became necessary to pack under the steel so the disc would go right through. Watch out for the fillings ,don't press too hard and if there is a plastic guard on the saw it may melt but if you look at the saw as being disposable you will find that it does the job well enough. It make a lot of noise so wear muffs as well as safety glasses.
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
posted on 28/12/07 at 09:07 PM Reply With Quote
Wood saws and metal saws do operate at different speeds and have different bores
Im not sure on fitting rage blades to a non rage machine but abrasive discs should be ok
Echidna
posted on 28/12/07 at 09:40 PM Reply With Quote
Could i use abrasive discs on my low-speed rage?
