speedyxjs
posted on 29/12/07 at 11:03 AM |
Welding pics - advice
Iv taken some pictures of my first full welds on my chassis and just wanted to make sure they were ok.
Sorry pics arnt as clear as i wanted.
Image deleted by owner
[img][/img]
Paul TigerB6
posted on 29/12/07 at 11:07 AM |
I'd have done my practicing on some offcuts myself - get all the settings right on them before attacking your actual chassis.
Mark Allanson
posted on 29/12/07 at 11:08 AM |
Sorry, but a bit more practice required. Try several welds on scrap section steel, then cut them up with a hacksaw and check the penetration. You can
also try a destructive test with a vice and a large piece of larger tube.
speedyxjs
posted on 29/12/07 at 11:09 AM |
I did. They looked ok on the scrap bits. I have only done a few tubes, so if these are too s**t i can grind them down and start again.
[Edited on 29-12-07 by speedyxjs]
mangogrooveworkshop
Looks a tad cold and have you degreased well enough
see http://www.mig-welding.co.uk/tutorial.htm
oadamo
posted on 29/12/07 at 11:17 AM |
2 much wire feed.
adam
r1_pete
posted on 29/12/07 at 11:20 AM |
Best thing to do is mock some joints up with scrap, weld them and then try to break them apart, the metal should break or bend not the weld, if the
weld breaks it is not strong enough and an equivallent weld on you chassis would be a weak point.
From your pics I cant see any grinder marks to clean the metal, before welding it needs to be clean and bright, not the blackened finish from the
stockholder, that has an insulating effect and interrupts the arc.
Also, as you progress the weld, vary the tip side to side slightly to make sure you are arcing against both pieces of metal, your welds do look a a
bit biased to one piece, you need to be sure the arc is biting the full thickness of the metal not just sticking metal to the surface, get close in
and look what the pool of metal is doing, you need to see a pool which is wider than the gap you are welding ensuring both peices are being melted.
At the ends of the box, grind the walls to 45 degrees, that way you are sure you're welding right through.
Dont skimp on the practice, remember, you are building a very fast car, and the stresses on the chassis are considerable, the finished product is only
as good as the foundation...
Regards.
Pete.
Paul TigerB6
posted on 29/12/07 at 11:24 AM |
quote: Originally posted by speedyxjsI did. They looked ok on the scrap bits. I have only done a few tubes, so if these are too s**t i can
It'd be a good idea to be honest. Have a go at replicating a couple of the actual joints with some offcuts and then test them as mentioned above
by Mark. You'll soon know when you have got it good enough.
thunderace
posted on 29/12/07 at 11:26 AM |
pump up the power and dont touch the wire speed the angle of the torch is also inportant push the wield dont pull it.
clean that mess up with a grinder.it will fail .
i have done a number of college courses over the years it cost around £200 for a night course that is one night a week for a year .
speedyxjs
posted on 29/12/07 at 11:30 AM |
Thanks for the replys. Some good advice. Back to the garage
Mansfield
posted on 29/12/07 at 12:17 PM |
Have you got two hands on the torch? A 9 lens helps no end as well.
TGR-ECOSSE
posted on 29/12/07 at 12:33 PM |
You are probably not getting enough penetration
Paul TigerB6
posted on 29/12/07 at 01:09 PM |
Ahem - a common problem for many men i recon!!
Mr Whippy
posted on 29/12/07 at 03:35 PM |
try using the Macro function (sometimes depicted by a flower) on the camera so it doesn't focus on the floor
bonzoronnie
posted on 29/12/07 at 03:55 PM |
Material ???
What material are you using ?
By the photos it looks to be box section as opposed to ERW square tube ??
If you are using box section, the ends of the tubes will need a little prep.
The weld looks as if it needs more current/less wire speed.
The metal itself looks clean enough. Just a quick wipe with thinners/spirit to remove any oil should be enough prep.
As others have said. A little more practise might help.
Dont forget to do plenty of destruction testing.
Ronnie
Mansfield
posted on 29/12/07 at 05:31 PM |
