Author: Subject: Another engine Mount Question - nut access
davidosullivan
posted on 31/12/07 at 01:09 PM Reply With Quote
Hi Guys,
I'm in the middle of making my own engine mounts and was looking at the fixings for the rubber mount/bush.
I'd rather have access to the nut than weld one into the engine mount. Does anyone see any problems in cutting a hole in the engine mount (as pictured... hopefully) to allow me to get a socket in.
[edit]... I should have put this on the diagram the main support is made out of 2" round steel tube.[edit]
Any help thanks.
EngineMountDiagram
EngineMountDiagram
[Edited on 31/12/07 by davidosullivan]
big_wasa
posted on 31/12/07 at 01:40 PM Reply With Quote
Looks fine to me.
You will want a drain hole to let water out.
I did mine like this
tks
posted on 31/12/07 at 02:49 PM Reply With Quote
i woud do it another way, maybe its overkill..
i would weldin a bushe with tig.
Then the forces are devided into the 2 walls of the tubeing and not only on the plane side wich touche the rubber. you then have as much acces to your nut as possible.
you will need a longer thread that is..
Tks
jacko
posted on 31/12/07 at 04:13 PM Reply With Quote
Hi have a look in my photo archives under engine stabiliser bkt
it may help you
Jacko
just cut the face of the box so you can grt to the nut
[Edited on 31/12/07 by jacko]
keith2lp
posted on 31/12/07 at 07:20 PM Reply With Quote
Engine mount
Tack weld the nut to the plate then you don't need to have access to the nut as you can screw the mouting rubber on.
I have used this method on both a pinto & duratec engines and is used by many kit manufacturers.
davidosullivan
posted on 1/1/08 at 09:56 PM Reply With Quote
Thanks guys, I decided just to weld it in.
Thanks,
To insanity and beyond http://www.davidosullivan.co.uk
