New Topic New Reply
Author: Subject: compomotive wheels on an INDY
kastrato
posted on 8/1/08 at 07:56 PM Reply With Quote
I am thinking to buy the 13" CXRs
I really like the back to be wider than the front. I also really like the looks of the CXR 8x13 in the back with 7x13 on the front.
http://s148.photobucket.com/albums/s30/kastratocliosport/spares%20MK%20indy%20racing/?action=view&current=untitled.jpg
http://s148.photobucket.com/albums/s30/kastratocliosport/spares%20MK%20indy%20racing/?action=view&current=fgu.jpg
The good news is that compomotive makes them the right offset (I think is ET35)
Do you think that the rear ones wouldn't fit? Please note that I am planning to use the car only on track mostly with slicks.
That way I believe the car will handle better on the corrners but with the cost of making the car a little bit slower but the above does not mean that I dont listen to other people opinions to the subject. Let me know yours please.
MK INDY fireblade
clockwork
posted on 8/1/08 at 08:01 PM Reply With Quote
"bigrich" has a set of these. You may wish to u2u him.
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
zilspeed
posted on 8/1/08 at 08:07 PM Reply With Quote
As does Athoirs as well.
StevieB
posted on 8/1/08 at 08:57 PM Reply With Quote
Will they fit over the rear disc setup?
TimC
posted on 8/1/08 at 09:19 PM Reply With Quote
They do on the MNR....
StevieB
posted on 8/1/08 at 09:45 PM Reply With Quote
As long as the MNR rear disc setup is from the sierra, it should be the same.
zetec
posted on 8/1/08 at 09:54 PM Reply With Quote
watch those 13" with rear discs, I suspect they wont fit, if they do they will be very very tight. I think the safest bet is 14"....
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
bigrich
posted on 8/1/08 at 09:57 PM Reply With Quote
205/60/13 on the rear are the same as 195/50/15 for gearing so wont affect top speed or speedo accuracy, they fit over the standard sierra disc set up with a slight tweak of the handbrake mechanism, or if your a sadist and want some work then they can be persuaded over wilwood handbrake calipers, but its not a straight forward conversion.
Also if your looking at 13 inch rims then there will be a new 13 inch team dynamics pro race 1.2 available very soon with a sample wheel to look at hopefully at the autosport show.
Mac#1 have commisioned the first production run so may be worth a look as an alternative to cxr's
athoirs
posted on 8/1/08 at 10:00 PM Reply With Quote
Hi Guys,
Yes and No
I have 13x8rear (245's) and 13x7'sfront (205's)on my indy
fronts are not a problem but the rear is.
even with max offset they will not fit over standard sierra disks AND fit under the arch. I had to go to fiesta (front) disks on the rear and turn down the hub to get it to all fit. also the caliper mount is now part of the rear upright. oh and the shock mount has to be moved inboard as well! You know the more I talk about it the more I wondered why I bothered!
Ill try and get some photos for you tomorrow
kastrato
posted on 8/1/08 at 10:49 PM Reply With Quote
I have drums in the rear. And I will upgrade to 4 pot in the front. Would they fit?
MK INDY fireblade
Pezza
posted on 9/1/08 at 12:19 AM Reply With Quote
I've got rear drums, and wilwood 4 pots up front. They fit fine for me.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
kastrato
posted on 9/1/08 at 04:43 PM Reply With Quote
Ok guys thanks for all the advice!
I order them today
compomotive 1370 PCD 108 ET19 front
compomotive 1380 PCD 108 ET19 rear
with tyres
Michelin slicks 20/54/13 soft front
Michelin slicks 22/54/13 soft rear
Hopefully will fit under my arches (I have the wide cycle arches in the front) I am not sre if they fit under the rear arches though.... will see...
Should be here in 3 weeks
MK INDY fireblade
athoirs
posted on 9/1/08 at 08:34 PM Reply With Quote
Mmmm Et 19 might be ok on the front but on the rear I think they will stick out about 1"
Good luck anyway- they are very good and light wheels!
[Edited on 9/1/08 by athoirs]
athoirs
posted on 9/1/08 at 08:39 PM Reply With Quote
not got any other photos at the moment Rescued attachment _forestburn 089.JPG
athoirs
posted on 9/1/08 at 08:42 PM Reply With Quote
kastrato
posted on 11/1/08 at 11:05 AM Reply With Quote
Do you think that ET19 is too much for the rear and will cause any problems?
I dont mind to modify the rear arches to make them fit but I dont want to modify anything else except the wheel arches.
I am preety confident that in the front I wont have any problems other than modify the cyrcle wing stays (supporters however they called anyway..)
MK INDY fireblade
Pezza
posted on 11/1/08 at 02:35 PM Reply With Quote
Sierras are Et 38 if i'm not mistaken
kastrato
posted on 11/1/08 at 10:21 PM Reply With Quote
yes sierra is ET38. But does this mean that ET19 would be not appropriate?
It is duable?
MK INDY fireblade
athoirs
posted on 12/1/08 at 02:03 PM Reply With Quote
I am sure you have, but if not go to the compomotive web site
http://www.comp.co.uk/info/technicalinfo.asp#
and have a look at their diagram on how to measure offsets. then get the steel ruler out and measure up the car, its the only way. As I said I think they will stick out about 1" but dont hold me to that.
kastrato
posted on 12/1/08 at 10:04 PM Reply With Quote
yes that would be ideal (to measure my car) but the car is in Greece and I am in UK. I just asking if anyone tryed before and know that it is actually fit.
Thanks for the info though!
MK INDY fireblade
New Topic New Reply
