Author: Subject: Dash Bottom Radius
posted on 15/1/08 at 04:33 PM Reply With Quote
Dash Bottom Radius
Hows the bottom of the dash for SVA? Does it pass as is or does it need some 'modification'
I can smell the finishing line now...
kev R1
posted on 15/1/08 at 04:53 PM Reply With Quote
yeah looks great with my special x-ray specs!
posted on 15/1/08 at 05:00 PM Reply With Quote
I can't see anything wrong.
worX
posted on 15/1/08 at 05:03 PM Reply With Quote
Well since you are posting clearly in the MNR section I'll assume you are referring to the MNR Dashboard? Then Yes they pass OK - the only thing you may have to do (for a fussy examiner?) is to put U Trim on the underside edge, but just take some spare and do it while your there...
posted on 15/1/08 at 05:17 PM Reply With Quote
Sorry chaps, I was indeed on about the MNR dash!
Thanks,
TimC
posted on 15/1/08 at 05:37 PM Reply With Quote
Getting close now Steve!!!
posted on 15/1/08 at 05:59 PM Reply With Quote
How close are you Tim? Considering your cheating now!
TimC
posted on 15/1/08 at 06:45 PM Reply With Quote
I'd be right up with you if my uprights hadn't gone missing in the post for 50-odd days.
The bodywork is on. The back-end is almost there. Front is awaiting machined uprights and pins, need to finish the plumbing and then set the whole thing up.
Close!
[Edited on 15/1/08 by TimC]
