Author: Subject: bonnet seal and rear panel edging/trim...?
foes
posted on 15/1/08 at 11:07 PM Reply With Quote
Right i'm in the process of fitting bodywork to my st locost and have a couple of questions regarding trim/edging...
1. What is the type of seal/trim that fits on the front edge of the scuttle and rear edge of the nosecone where the bonnet sits on to it?
2. I've just trial fitted the rear fibreglass panel and would like some kind of trim to finish off the top edge, what would look and fit the best?
Also where are the best suppliers to purchase them from?
Thanks for any info
DavidM
posted on 15/1/08 at 11:18 PM Reply With Quote
Try here, usually a good selection and good service:
http://www.woolies-trim.co.uk/
rjs
posted on 15/1/08 at 11:21 PM Reply With Quote
Davidm you beat me to it
http://www.woolies-trim.co.uk/c-322-extrusion.aspx
not much they havent got and i,ll second good service
foes
posted on 15/1/08 at 11:43 PM Reply With Quote
thanks for the quick replies, just had a browse on there, looks good.
whats the best type of material/style to fit between the bonnet and scuttle/nosecone..?
cheers
rjs
posted on 15/1/08 at 11:47 PM Reply With Quote
Hi
Mines just got the u trim around the joining edges on the bonnet .
http://www.woolies-trim.co.uk/images/PRODUCT/medium/1760.jpg
locoboy
posted on 16/1/08 at 09:24 AM Reply With Quote
Nice locost source of edge trim i discovered when stripping the range rover is the trim that goes all the way round the edges of the metal rear seat base and back, probably about 4-5meters in total.
probably free from your local scrap yard
Locoboy
Tangerine Scream
posted on 16/1/08 at 12:19 PM Reply With Quote
assuming you're using the ST bodywork, I just put a strip of this stuff on the lip of the scuttle and nosecone.
linky to woolies item
foes
posted on 16/1/08 at 01:04 PM Reply With Quote
Yeh that was more what i was thinking of, do some people use a D-section seal..?
cheers
