<<  1    2  >>
Author: Subject: Which Engine
lsdweb
posted on 19/1/08 at 03:29 PM Reply With Quote
Which Engine
Hi All
I'm trying to work out which engine to choose for my track build. It will be CEC (although I do have a spare 2005 R1 sitting on the bench...)
It will be a track car although may get used for sprints/hillclimbs and / or the occassional race in the Super Saloons and Roadsports class of the WRDA championship
I'm trying to work out which engine gives the most 'power to pound' ratio whilst being light as well.
I have bike (R1) throttle bodies and an Emerald ECU so that's a starting point.
The class structure for sprints and hillclimbs is up to 1700 cc (Zetec SE or Vauxhall?), up to 2 litre (Zetec and others) and over 2 litre (not sure if I want to go there!)
The race class is unlimited capacity.
Any thoughts guys?
I don't want to start another BEC / CEC debate by the way!
Wyn
Coose
posted on 19/1/08 at 03:33 PM Reply With Quote
I've seen a Striker with one of the Yamaha Puma 1.7 Zetecs (is that the SE?) and it's a very cute piece of kit! I don't know what bits are available such as cams etc. though....
Spin 'er off Well...
lsdweb
posted on 19/1/08 at 03:47 PM Reply With Quote
Coose
The 17 is the Zetec SE but it also has variable valves.
I saw one in a Fury last year and it looked so right - quite small and nice and light!
Wyn
ettore bugatti
posted on 19/1/08 at 03:49 PM Reply With Quote
Rover K-series is light too.
Duratec if you have the cash
zilspeed
posted on 19/1/08 at 03:57 PM Reply With Quote
Which is the busiest class ?
Up here (Scotland) The bigger sports cars tend not to be well supported.
posted on 19/1/08 at 04:11 PM Reply With Quote
ie If you are pot hunting which has the least competition.
A 1.6 K will have a handling advantage over other 1.6 and bigger engines.
Mark G
posted on 19/1/08 at 04:16 PM Reply With Quote
I used to have an mr2 with the 4age engine, That went well for a 1.6 (120 bhp). I know people have put these engines in locosts and they must go well.
Only down point is that the gearbox isn't easy to come accross.
iank
posted on 19/1/08 at 04:17 PM Reply With Quote
K series and ZetecSE are about the same weight. Either would make a good competition engine, but 1700 VTEC ZetecSE may make a little more power.
Anonymous
UncleFista
posted on 19/1/08 at 04:21 PM Reply With Quote
Ford Duratec, not the cheapest but the power people are getting from them is in a different league to previous Ford engines (well they would be, they're Mazda engines)
About half-a-metric-****load lighter than previous Fords too.
[Edited on 19/1/08 by UncleFista]
Tony Bond / UncleFista
lsdweb
posted on 19/1/08 at 06:04 PM Reply With Quote
Thanks guys
The 2 litre Duratec really appeals although this won't be a cheap option! An up to 2 litre car would be quicker in the open race class though. A Zetec ST 170 might be a good option???
Wyn
zilspeed
posted on 19/1/08 at 06:12 PM Reply With Quote
I would vote 2.0 zetec seeing as that's what I'm having.
However....
I know that a Vauxhall or a Duratec would spank it.
Ho hum
posted on 19/1/08 at 06:45 PM Reply With Quote
which pound do you mean - money pound or weight pound?
money pound i reckon would be 2.0 zetec (if you have a ford gearbox).
Volvorsport
posted on 19/1/08 at 07:03 PM Reply With Quote
i wont argue against all the other options , id stick a 5 cyl volvo in there , if there was room , lots of torque .
www.dbsmotorsport.co.uk
getting dirty under a bus
Paul (Notts)
posted on 19/1/08 at 07:29 PM Reply With Quote
The 1.7 zetec se in my puma gives 125 bhp as standard and with a better air filter and exhaust will give 130 bhp with no other mods.
the 1.7 from the racing puma has 155 bhp as standard.
Tuneing parts are expensive but in standard form it is a sweet engine and revs keenly from 3000rpm to 6500
Paul
TimC
posted on 19/1/08 at 07:42 PM Reply With Quote
Hi Wyn
In the same situation, there would only be one choice I'd make:
20V 4AGE on eBay
I've done a couple of trackdays with 4age powered Strikers also running and have been in Raw's old 20V demonstrator. No messing, this motor is a peach!
procomp
posted on 19/1/08 at 08:09 PM Reply With Quote
Hi the zetec se is good but if you are going to try and get it to 175 it gets expensive. Speak to MAWMAW on here he is the guy in KITS running one. Or pumawestie who is running the 245bhp one.
If you looking for 200 you either got to go zetec or vx but the vx is a bit heavier but gives more torque. Or as said look at the 4age but again if trying for 200 ish it gets expensive as has been proved by the works striker of Garry goodyear in kits.
£ for £ and reliability i would go vx or zetec. Giving 200 bhp
Cheers Matt
Hammerhead
posted on 19/1/08 at 11:16 PM Reply With Quote
1.8 k series can be tuned to 190 bhp without too much hassle. Also it is lighter than a 2.0 zetec. My elise has the 190bhp k series and it's pretty quick. My mk indy will have a 120bhp k series to begin with, with a view to increasing it to 190 bhp, so should end up being quicker than the elise!
I reckon the k weighs about 90kg plus gearbox.
Also could turbo or supercharging be an option?
edited to correct spelling errors!
[Edited on 19/1/08 by Hammerhead]
lsdweb
posted on 20/1/08 at 01:02 AM Reply With Quote
Thanks guys
Is this the Duratec?
Wyn
TimC
posted on 20/1/08 at 10:41 AM Reply With Quote
Cheers Matt
Undoubtably right - but, and this is a ridiculously subjective thing to say, the 20V seems to punch above its weight (meaning bhp and torque numbers) if that is at all possible...?
COREdevelopments
posted on 20/1/08 at 09:37 PM Reply With Quote
im gonna have to say 4age, revs well and later versions not far off 130bhp standard, which aint too bad for an old motor.
HTH
Rob
lsdweb
posted on 21/1/08 at 07:39 AM Reply With Quote
Thanks guys.
I'm trying to do a deal on a 2 litre Duratec which is a little bit more pricey than the Zetec / 4AGE but a more modern engine and almost 20kg lighter than the Zetec!
The bellhousing is the tricky bit although I read somewhere that it will bolt straight on to an MX5 box (being a Mazda designed engine).
Wyn
TimC
posted on 21/1/08 at 12:30 PM Reply With Quote
That's a bonus if thats the case. The Mx-5 box is one of the sweetest shifting there is... Boxster and S2000 are the only two that I've thought were as rewarding.
lsdweb
posted on 21/1/08 at 01:54 PM Reply With Quote
Tim
I can't remember where I read that so it could be absolute cr*p!
MX5 gearboxes aren't as cheap as a Type 9 either! Rescued attachment mx5GBX.jpg
NS Dev
posted on 21/1/08 at 02:09 PM Reply With Quote
caterham bellhousing, duratec to caterham box which is same as type 9.
as an aside, quite a few caterham c400 racers swapping to a new box (quaife instead of fettled caterham own brand) for the new regs this year (including our car).
Worth a phone call, I can ask graham how much he wants for the box from our car.
Not cheap but you only buy it once and it will still be expensive when you come to sell it some time in the future.
lsdweb
posted on 21/1/08 at 05:09 PM Reply With Quote
Thanks NS Dev
If you could get me a price although I suspect it may be out of my range!
It looks like I'll end up with a real mongrel of a car - Ford engine (Mazda design), Mazda gearbox possibly, Swift single seater uprights, Subaru diff (depending on weight), Emerald ECU (borrowed form my single seater), Polo rad and that's before I start building and looking for bits that'll fit!
Wyn
<<  1    2  >>
