Author: Subject: picture request zx12R
bikkel
posted on 20/1/08 at 08:40 PM Reply With Quote
hi there,
i noticed recently that my zx12r has ?no crankbreather pipe/hose.
Does anyone have a clea picture of the engine showing where the breather should be located?
i guess mine is blocked off by a bolt?
thanks
koen
www.zx12r-indy.tk
www.zx12r-indy.tk
posted on 20/1/08 at 09:02 PM Reply With Quote
This is about the only picture I can find that shows the crankcase breather on the ZX12R. The outlet is directly below the chrome K&N filter and connects to it via a short length of rubber pipe.
Phil
Crankcase breather
Crankcase breather
It's difficult to tell from the photo but the outlet for the crankcase is directly above the sprocket adapter and next to the top engine mounting.
[Edited on 20-1-08 by Hellfire]
bikkel
posted on 21/1/08 at 06:48 PM Reply With Quote
thanx hellfire
www.zx12r-indy.tk
posted on 21/1/08 at 07:38 PM Reply With Quote
No problem Koen. If you need any photographs from a different angle, just let me know.
Phil
Smartripper
posted on 21/1/08 at 08:06 PM Reply With Quote
Hello,
Maybe this can help
Daniel
[Edited on 21/1/08 by Smartripper] Rescued attachment 199.jpg
welderman
posted on 21/1/08 at 10:46 PM Reply With Quote
Thank's, Joe
I don't stalk people
bikkel
posted on 27/1/08 at 02:48 PM Reply With Quote
i think i found it:
but just 1 question be sure:
a blanking plug is bolted in a hole there;
is the breather thread horizontal and approx. 18 mm???
i will have to find a pipe that i can connect the hose on and lead it to the catch tank
answers/pics appreciated!
thanks
koen
www.zx12r-indy.tk
posted on 27/1/08 at 05:37 PM Reply With Quote
Hi Koen, that sounds like the one although it's 16mm.
The breather is circled in the photo below.
Phil
Crank Breather 1
Crank Breather 1
And a bit closer looks like this
From a slightly different angle. A bit blurred but should help ............
bikkel
posted on 27/1/08 at 08:53 PM Reply With Quote
thank u very much , HELLFIRE :->
my breather was invisible due to the wiringloom and engine mount blocking the view.
I will ask a friend with a lathe to make me one.
thx
koen
www.zx12r-indy.tk
