New Topic New Reply
Author: Subject: Fitting lower balljoints
MautoK
posted on 20/10/03 at 12:53 PM Reply With Quote
I'm about to fit the balljoints to the lower wishbones and not sure which fixings to use. The kit came with a huge selection of nuts & bolts but none seems right.
The nearest I've found are 8mm button-head screws but they don't look right in the 3/8" / 10mm hole; but they are OK for length and there's four of them.
These four screws bear the full static + dynamic weight of the front end so I'm looking for some reassurance that the generous clearance is OK - or do I need to source more suitable alternatives myself. A colleague has suggested they should be 12.9 rated which makes sense.
Any advice?
posted on 20/10/03 at 01:10 PM Reply With Quote
are they maxi ball joints? i would say most definitely get them the right diameter and length, as you say u dont want it falling off! i dunno much about tensile stuff but the more the merrier. my cortina ones came with the right bolts.
posted on 20/10/03 at 01:51 PM Reply With Quote
Mautok,
I have just fitted the lower ball joints to my Indy wishbones.
Don't know if they are in your kit (I got the basic kit), but I used 12.9 M10x30mm socket cap bolts and nylon self locking nuts with washers top and bottom. This should leave 2-3 threads exposed after tightening the nuts.
HTH
Nick
RichyMkIndy
posted on 20/10/03 at 10:33 PM Reply With Quote
the bolts with the kit only cover suspesion and wishbones i think.
me and greggors bought our fasteners
we bought the ball joint kit from MK
U2U greggors84 for sizes i cant remeber
MautoK
posted on 21/10/03 at 12:25 PM Reply With Quote
Thanks Nick.
I'll see whether the local screw-shop have any
MautoK
MautoK
posted on 24/10/03 at 12:41 PM Reply With Quote
Proper job!! Sorted.
On to the front uprights...
New Topic New Reply
