Author: Subject: MX5
wyatt
posted on 1/2/08 at 08:35 AM Reply With Quote
MX5
Has anyone used an MX5 as a donor and if so what parts did you take?
www.bynxy.co.uk
dave-69isit
posted on 1/2/08 at 08:52 AM Reply With Quote
jag used the engine and box in a stuart tailer chassie
JAG
posted on 1/2/08 at 09:13 AM Reply With Quote
Me again....
Lot's of questions about the MX5 these days
I finished my car about 2 years ago. I used the engine, gearbox and propshaft plus all the engine management bits and the ECU.
I coupled that to a MkII Escort back axle and used Cortina front uprights. There are loads of pictures of the part built and finished car in my photo archive.
If you want to know anything particular just drop me a U2U or email and I'll sort it out for you.
Justin
JonBowden
posted on 1/2/08 at 09:33 AM Reply With Quote
I'd guess that you haven't seen this site yet
http://www.cheapsportscar.net/
Keith Tanner has built his car using an MX5
Jon
wyatt
posted on 1/2/08 at 10:02 AM Reply With Quote
thanks I will take a look
I am considering updating my westfiled and thought I would look at the MK5 for a bit of insparation
www.bynxy.co.uk
onzarob
posted on 1/2/08 at 10:14 AM Reply With Quote
Westfield do a SDV using an MX5
liam.mccaffrey
posted on 1/2/08 at 01:33 PM Reply With Quote
im using engine, trans, front hubs, uprights all the braking system, rear hubs and uprights, diff and driveshafts and absolutely anything else i can modify utilise from the MX5
Build Blog
Build Photo Album
Keith Tanner
posted on 4/2/08 at 11:04 PM Reply With Quote
Westfield can definitely help you out. It depends on how much you wish to take from the MX-5, but as far as I can tell the Mazda SDV chassis is the same one used on the SEi-W. They even have a clever mount to put the MX-5 differential onto the Sierra mounting points.
I used pretty much everything. Engine, transmission, wiring (well, some of it), diff, driveshafts, uprights, brake calipers, steering column, steering rack (modified), seats, instruments and wheels.
www.slowcarfast.com
