<<  1    2  >>
Author: Subject: Changing gears (up) without using the clutch??
Alez
posted on 23/10/03 at 01:25 PM Reply With Quote
Hi All,
I just saw this in the Fisher Sportscars website, regarding the Fisher Fury Fireblade: "There is no need to use the clutch on up changes, just lift off and snap change."
Do you guys do that at all??? Is it something I'd like to do???
Alex
rell
posted on 23/10/03 at 01:35 PM Reply With Quote
yes i did this all the time in my XR3 right up untill i needed a new gear box
you can change gear just as fast with the clutch anyway
benedict
posted on 23/10/03 at 01:36 PM Reply With Quote
I certainly do it all the time, particularly when "going for it".
When you're about to change gear, just put some light pressure on the gearchange in the change-up direction. Then to change up just lift off the throttle for a tiny amount of time (before flooring it again) and it will slot fantastically quickly into the next gear up.
It's certainly the fastest gearchange I've ever used/had/done in a car
Ben
benedict
posted on 23/10/03 at 01:41 PM Reply With Quote
Presumably though that had a H-pattern synchro box not a sequential dog box like on a BEC. I think with a car engine it probably is quicker or as quick with using the clutch but with a bike engine it's a different kettle of worms.
Ben
[Edited on 23/10/03 by benedict]
posted on 23/10/03 at 02:12 PM Reply With Quote
Perhaps this link will help...
Hewland
This is talking about sequential boxes in a racing car, but the internal mechanism is much the same as on a bike.
I've done this on a bike going up the gears, but I really don't fancy doing it on the way down!
DJ
[Edited on 23/10/03 by David Jenkins]
Jon Ison
posted on 23/10/03 at 03:56 PM Reply With Quote
alex, the clutch is totaly redundent on up changes, just ease of the throttle n pull.
Jasper
posted on 23/10/03 at 04:21 PM Reply With Quote
And man it feels sooooo good - even my dad's getting the hang of it - now just got to get him to heal and toe on the way down or I'll be looking at another gearbox again!
BTW - last track day I did there was a Megabusa with a turbo charger (beautifully installed) AND Nitros - he is either mad or has very large kahones (Alez - please help with the spelling there).....
benedict
posted on 23/10/03 at 05:44 PM Reply With Quote
or push - if like me you have the gear lever ar$e-about-face to everybody else
ChrisGamlin
posted on 23/10/03 at 06:30 PM Reply With Quote
Having a more natural feeling (for me anyway) pull-to-go-up gearchange, I dread ever being offered a drive in a BEC with a push-to-go-up change, I bet within 3 laps I would have buzzed the engine!
Regarding clutchless upchanges, yep I do it when I think about it, although natural reaction is still to plant the left foot to use the clutch.
benedict
posted on 24/10/03 at 10:48 AM Reply With Quote
I think you're lucky (sensible!) in that respect in that it's extreeeemly unlikely (In my experience) that you're likely to come accross a car, other than mine(!), that's push to change up. IIRC pretty much all seq boxes for cars, whatever the engine, are pull-up.
I chose the opposite as it seemed more natural to me at the time, though in hindsight wish I'd done it the normal way 'cos I'm likely to buzz an engine in the manner you describe if I ever drive a different seq-shift car.
I could change it in my car and "re-train" myself, but I fear I would probably need a good supply of engines standing by while I got used to it
Ben
PS
Chris - am I dreaming/confused (very likely) or was it you who used a westfield fit carbon(?) dash on an ST scuttle???
MK9R
posted on 24/10/03 at 11:00 AM Reply With Quote
I've gone the push to go up root as it seemed more logical. Plus i reckon it feels easier/quicker to go down a few gears using your fingers to pull rather than pushing using your arm.
My cars not on the road yet, so WTF do i know
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
benedict
posted on 24/10/03 at 11:21 AM Reply With Quote
Wow!!! another similarly warped individual
Well that's now doubled the number of push-to-go-up cars I know of ....... to 2
Maybe I'm not so wierd afer all.
Ben
[Edited on 24/10/03 by benedict]
MK9R
posted on 24/10/03 at 11:27 AM Reply With Quote
you can let me have a go in yours then now to get some practice in before mine is finished!!
Cheers Austen
RGB car number 9
www.trackace.co.uk
Mk-Ninja
posted on 24/10/03 at 11:29 AM Reply With Quote
A mate of mine has a fury thing and hes just changed his to push for up because his gear change on his Audi works that way, so I dont think it can be as unusual as you think, the only thing is now I dont know which way to do mine because Im sure we will drive each others cars.
Gordon
I'm sure I've got one, just don't know where I've put it
posted on 24/10/03 at 11:32 AM Reply With Quote
How about changing it around, and fitting a rev limiter?
benedict
posted on 24/10/03 at 11:42 AM Reply With Quote
'cos when you're doing 12500rpm and you change down instead of up, a rev-limiter isn't going to help much!!!
Ben
posted on 24/10/03 at 11:52 AM Reply With Quote
Ben
Good point!
I was thinking about stopping the engine driving itself to destruction, but that doesn't stop the car's momentum spinning the engine to pieces...
DJ
ChrisGamlin
posted on 24/10/03 at 11:53 AM Reply With Quote
Yep it was me, I fitted one of the Plays Kool Westfield dashes to my ST scuttle, fits fine as it its the same width and height is no problem as its a large square shape which you shape yourself to the profile of the scuttle top. It also tidies up the sides nicely as it is shaped to cover up the scuttle all the way down to the side chassis rails, so hides (in my case) some rather unsightly ST fibreglassingon that area of the scuttle.
regarding the gear changing, I know Ian Gray does (did?) usually fit them as a push-to-go-up, with the logic that you push forward to go forwards faster, and pull back to slow the car down, but to me when you are accelerating and being pushed backwards into your seat, its natural to pull back, and when you are braking and being flung forwards, you push forwards.
Some semi-auto cars use a push-to-go-up tho, such as the Smart.
[Edited on 24/10/03 by ChrisGamlin]
Alez
posted on 24/10/03 at 12:07 PM Reply With Quote
Cheers guys!
Good stuff, I thought it may be OK for up shifts and actually I used to do it all the time with my motorbikes (even down shift sometimes, I have to admit).
Pulling for gear up feels more natural to me as well: When you do up shift you are usually accelerating, so the new gear will pull your body if you know what I mean (excuse my English). When you do down shift you are usually deccelerating, so when you release the clutch your body with be pushed forward.
Jasper, pronunciation probably the same, spelled "COJONES"
Alex
Alez
posted on 24/10/03 at 12:09 PM Reply With Quote
David,
Excellent article about gear changing, really.
benedict
posted on 24/10/03 at 12:22 PM Reply With Quote
cheers - I'm looking at putting a new dash on as I've cracked mine in a couple of places including where I'd mounted the choke (now relocated to the s/colm mount behind the dash).
What's the playskool one like quality/value wise and is it wet-lay or pre-preg?
I was thinking about the fluke motorsport one which is pre preg - though I notice that I've now missed the £56 offer they had on!!!
<snip>
I didn't know that - excellent I'm not such a wierdo after-all
Ben
Edit:
PS if you do go to the fluke-motorsport website then check out a non-existant link on their site such as this one and sit and read the error message that writes out.
Fantastic
Simon
posted on 24/10/03 at 12:29 PM Reply With Quote
With a bike engine, you should be able to go up and down the box without the clutch - though down will take a bit more practice (NOTE - most bike manufacturers say in their owners manuals that the g/box isn't designed for clutchless changes).
For those of who are really keen to go up the box asap, get an electronic cut out fitted - it saves closing the throttle, just cuts a couple of sparks!!
Simon
ChrisGamlin
posted on 24/10/03 at 12:53 PM Reply With Quote
Ben, the Fluke one is probably better quality carbon (pre-preg) but it doesnt have the same shape as the Plays-Kool one, it just does straight across and so leaves the sides of the scuttle unfinished, if thats a concern to you.
Chris
Jasper
posted on 24/10/03 at 01:06 PM Reply With Quote
Or buy a piece of carbon and make you're own!
ChrisGamlin
posted on 24/10/03 at 01:23 PM Reply With Quote
Doesnt have a rolled lower edge if you do that - SVA issues if you havent already passed
<<  1    2  >>
