lsdweb
posted on 6/2/08 at 10:05 PM |
BEC 36/1 trigger wheel
Hi All
I just thought I'd post a picture of the new trigger wheel in my R1. Some of you may remember I was running an external trigger wheel on my 5JJ
motor but that was pretty complicated and troublesome so I wanted to do it properly on the 5VY engine!
So, here it is-
![](/galpreviews/a688491-SNV30453.JPG) ![Rescued attachment SNV30453.JPG](/gallery/a688491-SNV30453.JPG) Rescued attachment SNV30453.JPG
cossey
posted on 7/2/08 at 09:57 AM |
those teeth look tiny. have you check wether you get a good enough signal off of then whilst cranking?
im planning to put a similar sized wheel on my 5vy but havent yet because i wasnt sure if teeth that small would give a good enough signal using the
stock vr sensor.
TimC
posted on 7/2/08 at 10:44 AM |
Nice... I'm not surprised Henryk is upgrading as well!
lsdweb
posted on 7/2/08 at 01:13 PM |
That was my concern! I've spoken to Chris at Trigger wheels at length over this - he's tested this size wheel with a stock sensor to over
20000 rpm. I've yet to have it running as the engine's still out of the car and the ECU is still with Emerald.
Tim - Henryk's upgraded to the latest R1 with the variable intake trumpets - I hate him :-)
Wyn
clutch_kick
posted on 7/2/08 at 04:31 PM |
nah the wheel looks fine to me. Shouldn't be a prob getting the signal.
cossey
posted on 7/2/08 at 05:44 PM |
Wyn
with a vr sensor the amplitude of the signal increases almost exponentially with speed so the real issue is whether the ecu can read it at cranking
speeds.
lsdweb
posted on 7/2/08 at 07:15 PM |
speeds.
Chris has also tested it with the same kind of processor used by Emerald apparently.
Here are the original and 36/1 wheel side by side.
![](/galpreviews/a688893-trigger.jpg) ![Rescued attachment trigger.jpg](/gallery/a688893-trigger.jpg) Rescued attachment trigger.jpg
imp paul
posted on 7/2/08 at 07:33 PM |
im wanting 1 to fit my zx12r think it needs a 2.75 36 tooth Joby but can not get 1 as i have only seen 2.5 and 3.0 and so on i need this to run my
dta mite have to get the 2.5 and see how it turns out ![](/images//smilies/smile.gif)
lsdweb
posted on 8/2/08 at 08:38 AM |
Paul
Contact Chris at Trigger wheels - he's very helpful and may be able to sort you out!
Wyn
chunkytfg
posted on 8/2/08 at 10:41 AM |
silly question but whats the purpose of it?
lsdweb
posted on 8/2/08 at 03:43 PM |
I'm running an Emerald ECU which, like a lot of aftermarket ECU's aren't designed to pick up on some of the bike trigger wheels,
hence the 36/1.
chunkytfg
posted on 8/2/08 at 03:52 PM |
hence the 36/1.
Ahh okay that makes sense now.
