Author: Subject: Roll Bar for a Tall Guy :-)
Omni
posted on 19/2/08 at 02:55 PM Reply With Quote
Hi Guys,
I am assuming that I will need a higher roll bar due to being 6' 4" tall. lol. Anyone know the correct height?
Also does it have to be bolted in or can I weld it straight to the chassis?
O
Kriss
posted on 19/2/08 at 03:14 PM Reply With Quote
i am 6' 5" and sat in MK's, Westfield and Caterhams all of late. None of which seem to have a dramatically low roll bar that I noticed.
Can weld in or bolt (3 bolts to chassis) and back stays can be welded or rose jointed.
My mate has a standard Westfield Megabusa Roll bar for sale left over from his build.
Can find out how much he wants if need be!
mad gaz
Builder
Posts 190
Registered 20/9/07
Location doncaster
Member Is Offline
Photo Archive Go!
Building: indy blade built indy spec r ,another indy r busa
posted on 19/2/08 at 03:21 PM Reply With Quote
my son is 6,3" and fits in our mk indy no probs .MK will provide you with a rollbar flat pack Rescued attachment gulf indy 005.jpg
bassett
posted on 19/2/08 at 03:44 PM Reply With Quote
Hi, i know the guys at MNR weld them but you see most westfields are bolt on so doesnt really matter which way you do it.
As for the height, MNR measured ours from the highest point at the front going upto the roll bar and made sure when we were sitting in the car there was 2 inches on top of our head for a helment then 3 inches for clearance which is required for race use if i remeber correctly
gingerprince
posted on 19/2/08 at 04:08 PM Reply With Quote
I had MK make me a custom one for my lanky self ( 6'4" ). My seat is not on runners it's bolted via 20mmish box section directly to the floor so as low as the seat can be. Can measure height of bar if you want, but you'll be best getting someone to measure up with you sat in your car with helmet on. should be high enough such that a straight line can be placed between the top of the rollbar and the front of the nose (technically the top-front of the structural chassis) with your head underneath.
[Edited on 19/2/08 by gingerprince]
Omni
posted on 19/2/08 at 05:24 PM Reply With Quote
BLIMEY YOUR CAR LOOKS AWESOME! WELL DONE!
O
big_wasa
posted on 19/2/08 at 06:55 PM Reply With Quote
I am 6'3"
I sat in mne with a helmet on and made it 50mm over the top of that.
It looks to hight but its not there for looks.
Nick
posted on 11/3/20 at 06:49 PM Reply With Quote
I know this is an old post, but.... Have you still got the car. Cis I have a question.
What is the height from the top of the scuttle to the centre line of the roll bar please.
Mr Whippy
posted on 12/3/20 at 07:14 AM Reply With Quote
O
ditto, one of the best
big_wasa
posted on 12/3/20 at 12:49 PM Reply With Quote
Who are you asking mate?
Nick
posted on 12/3/20 at 01:06 PM Reply With Quote
I thought I'd edited it. It was directed to mad. Gaz.
