Author: Subject: Aldi air compressor and extras
bob
posted on 25/2/08 at 12:50 PM Reply With Quote
Back again
aldi link
Bluemoon
posted on 25/2/08 at 12:58 PM Reply With Quote
Still happy with my two (connected via the 2nd outlet that's direct to the tank).I have found the air drill very useful, more accurate that my electric one..
Dan
ash_hammond
posted on 25/2/08 at 01:01 PM Reply With Quote
am i correct in thinking this is not powerfull enough to run airtools? ie impact guns?
- Ash
.: www.mac1motorsports.co.uk | www.m1moc.com :.
Bluemoon
posted on 25/2/08 at 01:02 PM Reply With Quote
Works better than most.. I have two compressors and the second hardly ever comes on.. The 4cfm tools are fine.. For the price the compressor is bigger than ones at the same price from machine mart etc. (in fact I think SIP do the same one for around 200 notes)
Dan
[Edited on 25/2/08 by Bluemoon]
DaveFJ
posted on 25/2/08 at 01:20 PM Reply With Quote
happy with mine but as stated above, not good enough to run an air drill
Dave
MikeR
posted on 25/2/08 at 02:10 PM Reply With Quote
Dan
Dan, can you detail your setup - i've thought about doing the same but a mate insists i need to get one way valves or else i'll blow the pressure switches in both compressors.
matt_claydon
posted on 25/2/08 at 04:48 PM Reply With Quote
Can't see why you would need any valves or anything, just connect directly. You aren't increasing the pressure in any way, just doubling the storage capacity and max flow rate. The pressure in both tanks will always be equal and the pumps should both come on and off pretty much together.
Johneturbo
posted on 25/2/08 at 05:07 PM Reply With Quote
Do you think this would have enuff ummph to run an impact gun?
zilspeed
posted on 25/2/08 at 05:14 PM Reply With Quote
I have that compressor and impact gun from last year's deal.
The good news is that the impact driver will work, but expect the compressor to run after maybe 5 - 10 seconds of heavy use.
wacomuk
posted on 25/2/08 at 07:32 PM Reply With Quote
my dad used to have a small compressor and found it struggled with certain things (spraying air tools etc)
he got hold of an largish old gas bottle (free) and connected it in line. this gave much longer spray time or tool use
http://www.insightbookingsolutions.co.uk
posted on 25/2/08 at 07:38 PM Reply With Quote
i used to run a pair together, it works fine and ups the fad nicely. If you were keen you could add a tank to store more.
Bluemoon
posted on 25/2/08 at 10:04 PM Reply With Quote
MikeR.. Just conected the high preasure outlets together, they are connected directly to the tank before the regulator. Somthing the manual fails to tell you. On the face of it you would think both are regulated untill you realise were both the preasure gauges are plumbed in..
Works well as both compressors have diffrent settings of on/off preasure (tolerance I guess) so only two come on when using large mounts of air, most of the time only one comes on.. With the amount of stored air (48ltr) I can drill 2 or three holes on the chassis without the compressor(s) starting..
The only thing to watch out for is that becuase you use a male quick coupler on both ends of the hose connected them you can empty the tank directly if you remove one by acident. Not nice dont fancy hose wiping about with 100psi air coming out the end.. To stop me doing this durring a laps of concentration (happens to offten!) a cablet tie around the coupler stops them being undone.
I also have an oil speperator in the outlet side, else you will get oil vapour/water in the hoses etc.
It works for me, have had no problem with lack of air using the aldi tools (drill and ratchet). Not tryed spraying yet..
Just remember two makes more noise than one!
Dan
omega 24 v6
posted on 25/2/08 at 10:17 PM Reply With Quote
Am I readinf the add right?? Are the air brush kit and the accesories kit supplied as well at that price???
Bluemoon
posted on 26/2/08 at 08:37 AM Reply With Quote
Yes (last time they were on offer)... Mine came with
Small airbrush
Gravity feed spray gun
Blower
Tire inflater
Paraffin type gun
Hose
[Edited on 26/2/08 by Bluemoon]
fatfranky
posted on 26/2/08 at 09:32 AM Reply With Quote
I thought that was the thing that you were supposed to avoid, i.e. two 2.5 HP motors kicking in together due to the high start up current drawn.
I have a 3HP belt drive compressor with a 200 litre tank, the pressure switch has a removable cover where you can adjust the pressure at which it switches on. If i were running 2 in tandem i would ensure that they do not kick in at the same time. As Bluemoon suggests if they happen to do this as supplied then that's fine.
ps I intend to get one myself as my compressor takes a loooonnnnngggg time to fill that big receiver and a small one will be great for little jobs.
Bluemoon
posted on 26/2/08 at 12:17 PM Reply With Quote
No problem about coming on at the same time.. It's not really an issue as they don't, if you think about it it's nearly impossible unless the switch is set to exactly the same pressure...
Dan
Jasper
posted on 29/2/08 at 11:26 AM Reply With Quote
Thanks for the heads up on this one - we finally have a new Aldi near us, went in this morning and bought the whole kit, compressor, airline extension, drill, die grinder, ratchet, impact gun, cut off saw, oil for everything all for £192 - BARGAIN - thanks guys , can't wait to set it all up and have a play ....
