Author: Subject: identify zetec water inlet for me
Blackwater
posted on 1/3/08 at 10:33 AM Reply With Quote
Hi
I´m not sure of it´s correct technical name but help me identify these out/inlets and electrical contacts
it´s a silvertop -95 i think
left side engine
left side engine
1. to expansion can?
2. to?
3. to?
4. contact for
right side engine
right side engine
1. oil?
2. water?
3. contact?
excuse the poor photo quality. it´s my mobile phone as my digital camera is crap right now
[Edited on 1/3/08 by Blackwater]
Hope you can read and understand my english
SeaBass
posted on 1/3/08 at 11:16 AM Reply With Quote
1 - Top of Header Tank
2 - Radiator Top Hose
3 - T piece on bottom radiator hose to help with over cooling.
4 - ECU temp sender I believe / Instrument Sender is on the top if you have one?
1 - Oil breather pipe
2 - Bottom of expansion tank.
3 - In the bin
The only other water connection is then the bottom radiator hose which is connected to the water pump. I put a T piece in to connect to 3 in the first image as recommended by Westfield builders. Ran fine like this for over a year.
[Edited on 1/3/08 by SeaBass]
Schrodinger
posted on 1/3/08 at 02:02 PM Reply With Quote
3 - In the bin
I agree however:
Top Pic
3 is the thermostat bypass and is only open when the thermostat is closed to allow for a flow of water around the engine and stop hot spots in the engine.
Bottom Pic
2 I would be a bit loathed to direct that to the header tank as it is intended for a heater and so will flow at all times the engine is running but it does depend on the radiator you are using. One other tip have a look at the thermostat and you will see there is a little ball bearing in the plate if this is prised out it will help to bleed air out of the system.
have a look at
[Edited on 1/3/08 by Schrodinger] Rescued attachment cooling-system-r2.jpg
Keith
Aviemore
SeaBass
posted on 1/3/08 at 03:26 PM Reply With Quote
This site goes to town on all the options. I opted for a layout that was as simple as possible but still effective.
http://www.emeng.gentlyhosting.co.uk/Cooling/Part1.htm
Blackwater
posted on 1/3/08 at 05:38 PM Reply With Quote
thanks for the replyes.
I´mnot gonna use any heater in my car, forgot to say that. And i´m hopefully use Megasquirt
Pic 1
4. yes there is one at the top and the other one under as the picture
Pic 2
3. thow away. what is it for in a ordinary mondeo?
bob
posted on 1/3/08 at 05:42 PM Reply With Quote
I have no heater so number 2 pic number 2 outlet is now blocked off, header tank runs straight round to T-piece in bottom hose.
pics in my archive of zetec plumbing.
