Taz Surfleet
| posted on 6/3/08 at 04:36 PM |
dohc advice requested
have a 2.0 dohc 16v which came out of a scorpio there seems to be quite a few differences between this and the 8v (stating the obvious) is it worth
using this engine or should i just got straight to a zetec? when everything is stripped off it It dont seem to be that heavy !! and yes the crank is
in there
| posted on 6/3/08 at 04:39 PM |
Very expensive to rebuild and not much tuning available for them.
You may be able to pick up a zetec for the price of a set of gaskets for the dohc!
big_wasa
| posted on 6/3/08 at 06:15 PM |
As above but whats your budget ?
If you are doing a budget build then use the budget engine.
Sort of wished I had, atleast I would be driving it with the option of winter upgrades.
Taz Surfleet
| posted on 6/3/08 at 09:42 PM |
I got three of them on the go and this one was going to be a seller to finance the other two! but for the sake of £100 may be worth just going with a
zetec!!
