Jubal
posted on 16/3/08 at 04:32 PM |
Fuel Sender for Koso Dash
Does anyone know what fuel senders would be compatible with the Koso RX-1N dash and might fit here without too much trouble? I think it supports
either 100 or 510 ohm resistance. I clearly need a new one as mine has gone walkabout
twybrow
posted on 16/3/08 at 04:37 PM |
I've got a Honda Blackbird gauge fitted. Works well (but took a lot of wire bending to get the swing right!).
Jubal
posted on 16/3/08 at 05:38 PM |
I'll give one a try. Thanks. Any tips on getting the tacho working? Mine shows just under half revs at present?
twybrow
posted on 16/3/08 at 05:56 PM |
The only way I coud get the tach to work was using the original bike gauge input wire from ECU. Are you sure you have the correct setup for
cylinders/2 or 4stroke sorted?
worX
posted on 16/3/08 at 10:09 PM |
Unbelievable...
welderman
posted on 17/3/08 at 07:48 AM |
Derek, has it fallen off or just been removed ?.
Sorry i cant answer your question though mate, but it looks like a botch job to me that.
Thank's, Joe
I don't stalk people
Jubal
posted on 17/3/08 at 11:27 AM |
What can I say? It's not in the tank as far as I can see. I've never opened the tank up before yesterday. I must therefore conclude that
it was removed during the recent work and not replaced. No wonder the fuel gauge on the Koso dash was proving tricky to get working.
