Author: Subject: Sorry...Diff oil again
paulmw
posted on 22/3/08 at 01:09 PM Reply With Quote
I have a Sierra 3.62 LSD. I know the LSD unit is sealed and it can take normal diff oil
However, I cant get the plug out of the back of the diff and wondered if I could put the oil into the breather pipe
If so I dont know ho much to put in and if I over fill it will this cause a problem?
Thanks Paul
stevec
posted on 22/3/08 at 01:15 PM Reply With Quote
May be you could make a dipstick out of welding rod or stiff wire. Then measure the height of the plug from the base.
I think they hold just over 1ltr.
Steve.
viatron
posted on 22/3/08 at 01:46 PM Reply With Quote
I had the same issue and in the end welded a bolt into the recess in the top up plug and "beasted" it out, refilled and fitted a new one with lots of copaslip and new fibre washer.
[Edited on 22-3-2008 by viatron]
jacko
posted on 22/3/08 at 02:27 PM Reply With Quote
I had the same .
I made a slot across the plug with a cutting disc in a mini grinder then used a flat bar to undo the plug
itiejim
posted on 22/3/08 at 02:40 PM Reply With Quote
They hold just under 1 litre according to the book in Halford - I'm sure a litre would be fine.
