Author: Subject: Zetec piston differences black and silver top.
paulf
posted on 22/3/08 at 08:09 PM Reply With Quote
Ive been thinking about building a turbo zetec but dont want to use a decompressio shim or buy forged pistons.I have found out the black top pistons have a lower compression height than the silver top pistons by about 3mm, the gudgeon pin size also seems to be smaller at about 19mm instead of 20,8mm.
I am going from info i found on the web , can anyone confirm this?.
My idea is i could use black top pistons , slightly shorten the block and make some bushes and end caps to allow me to have floating gudgeon pins in the silver top rods.
The other option is to use standard compression ratio and keep the boost to about 7 or 8 psi and see what happens.
Paul
big_wasa
posted on 22/3/08 at 08:15 PM Reply With Quote
another option.
There is a firm who can drop the CR by CNC porting the head.
This means if you blow the bottom end its a cheap fix.
Its the way I am looking into.
JEPY
posted on 22/3/08 at 08:22 PM Reply With Quote
Hi Paul,
Think the overall compression of the black top is similar to the silver top earlier versions. Although the gudgeon pin is closer to the crown of the piston, this is compensated for with a longer conrod.
Keep your boost low, use higher octane fuel and plenty of cooling (either big intercooler or charge cooler) and you might get away with it. Or add NOS - keep your charge temps nice and low and good power increase
Alternatively, I'm looking to fit a rotrex supercharger and keep the boost low. Bonus with this setup is much lower heat generation than a turbo and less likely to detonate.
J
Zetec turbo is on the carbs for me too
My plan was to use standard Vauxhall forged turbo pistons. They have a smaller, i believe, gudgeon pin diameter and are bigger than zetec ones. With a bore out it takes the zetec to 2.1L and a low comp ratio.
I'm also under the impression the 2L head on a 1.8 gives a lower comp ratio that may be good for experimental reasons. So, at the moment I have a spare 1.8 engine a 2L head and a Rover turbo inlet manifold.
Searching the bay for a Nissan 200 turbo to go on a Focus tubular exhaust manifold.
paulf
posted on 22/3/08 at 08:34 PM Reply With Quote
I briefly considered the 2 litre head on an 1800 block but dont think it would work as you would end up with a step at the top of the bore where the head is a larger diameter. I think this would disrupt combustion and possibly lead to preignition due to the sharp edge.
I thought the black top pistons with the silver top rods would end up 3mm lower than the silver top pistons which would lower the ratio by plenty.
I have considered the vauxhall pistons but still expensive unless used then they are an unknown .
Paul
paulf
posted on 22/3/08 at 08:37 PM Reply With Quote
The Subaru turbos seem ok , there are plenty available cheap on E bay from upgrades.Thats what i intend using , Madteg on here has one fitted .
Paul.
Schrodinger
posted on 22/3/08 at 08:56 PM Reply With Quote
I'm sure that I've seen decompression plates for the Zetec on Ebay for use if the head has been skimmed too much or to lower the compression if turbo ing
Don't know if they are any good though.
Keith
Aviemore
posted on 22/3/08 at 10:02 PM Reply With Quote
Decompression plates in general should be avoided, especially for turbo use.
Dusty
posted on 22/3/08 at 11:09 PM Reply With Quote
Another option would be to skim the top surface of the standard pistons to lower the compression ratio.
paulf
posted on 23/3/08 at 04:15 PM Reply With Quote
Yes have considered that, but supposedly they are weak to start with so may not be any better than leaving standard and using low boost although had thought of machining a dish in them so leaving the outside full height to give some strength and also keeping a squish band.
Paul
paulf
posted on 23/3/08 at 04:17 PM Reply With Quote
I would imagine that to do this would be expensive as you cant remove much material without altering the valve seats which would then be expensive.
Paul.
Originally posted by big_wasa
another option.
procomp
posted on 24/3/08 at 10:28 AM Reply With Quote
Hi if it is of any interest to any one. Here is a LINK to a 2ltr zetec with an Eaton M45. Some useful info on parts used for conversion.
Cheers Matt
