New Topic New Reply
Author: Subject: Just starting a build, any opinions on stainless tube?
Digger Barnes
posted on 11/11/03 at 01:57 PM Reply With Quote
Hello all I am just about to start a BEC Locost build. I am in the process of getting all the tools together to start. I have taken a week of work and had lessons in TIG welding by our on site fabricators/pipe fitters. So I have just acquired a TIG welding plant.
Now for the question. I have not seen mention of people fabricating their chassis from stainless steel is there any particular reason for this?
My initial thoughts are that I would like to build using 304 grade. I have just costed the price for the material and it would be in the range of £220 for the complete chassis excluding roll bars (this is with tube of 1.5mm wall thickness). So I don't think that the cost is prohibitive.
I know that stainless is stronger than mild so the slightly reduced wall thickness should not be a problem should it?
Are there any known problems of stress cracking in stainless chassis?
Any opinions info appreciated
G
Alan B
posted on 11/11/03 at 02:07 PM Reply With Quote
Digger, the general concensus is don't do it....
No offence meant, but if you need to ask these sort of questions you aren't expert enough in welding stainless....I know I'm certainly not expert enogh...yet I'll MIG mild steel all day without any concerns....
Stick with regular mild steel is my advice...
Some may disagree of course..........
UncleFista
posted on 11/11/03 at 02:20 PM Reply With Quote
Dr Hess (I think, its been a while) a brain surgeon no less is/has built a SS chassis for his locost. Can't remember whether he's from the US or Aus but he used to post on the Yahoo list.
The Yahoo list is archived so have a search on there
HTH
Tony Bond / UncleFista
Alan B
posted on 11/11/03 at 02:30 PM Reply With Quote
Mr Hess..(I refuse to call him doc on a car list...if he's examining me no prob, then he's doc....)...is in the US...Arkansas I believe...pretty certan he's more of a GP than brain surgeon though...
His build is well documented IIRC...he posts on Locost NA...he swears by Stainless....
UncleFista...not a dig at you BTW....just a rant about misuse of titles that's all....
Digger Barnes
posted on 11/11/03 at 04:19 PM Reply With Quote
Cheers I will do a search to see what I can dig up.
As to "No offence meant, but if you need to ask these sort of questions you aren't expert enough in welding stainless....I know I'm certainly not expert enogh...yet I'll MIG mild steel all day without any concerns.... "
I am not concerned about the quality of my welds, before my life as a chemical process engineer I was a toolsetter/fitter and I had to do a lot of arc/mag welding. I got trained up on the TIG last week and we tested number of my welds and non failed before the material did.
The issue of stress cracking I was refering to was from possible chloride corrosion that affects the grain structure of stainless under certain conditions. I have come across this condition a number of times on our plant, but in the real world of normal temperatures and pressures I do not know how stainless performs.
The reason I want to use stainless is because I want the chasiss to be as strong as possible and completly unpainted without the fear of tin worm setting in at some point in the future. Of coarse TIG welded stainless also looks great, nice smooth welds without any splatter.
So I was really looking to find out if there were any inherrent problems with using a less maliable materal, such as unusual handling characteristics because of a higher youngs modulus of the steel.
G
[Edited on 11/11/03 by Digger Barnes]
Alan B
posted on 11/11/03 at 04:51 PM Reply With Quote
Hi Digger,
I'm sure glad I said "no offence meant..."........it was based on your apparent novice status.......which is not the case.
Clearly, your expertise is not in question....however most people who say "can I use SS/Ali/cromoly etc?"...I would still say if you have to ask then the answer is no.......
I realise now your question is somewhat different.....I don't have the expertise to say specifically why not SS......more a case of why mild steel is simpler, cheaper and consequently most often used....
BTW, I agree that well tig'd SS is gorgeous...
Does SS actually have a significantly higher Youngs modulus?..I though all steels were pretty similar.....tensile strengths vary of course......a lot..
[Edited on 11/11/03 by Alan B]
Hugh Paterson
posted on 11/11/03 at 05:45 PM Reply With Quote
Stainless steel
Digger, I suggest you have a look at the tensile strength of the stainless steel chassis in 304 and compare it to CDS tube. The stainless would be a good idea however if you intend to "bond" the panels for the floor pan and panels with exotic materials like kevlar or carbon and say Sikaflex. I have toyed with building a chassis in stainless too but opinion from automotive engineers is that the CDS is better, but hey how many crap cars have u seen designed by so called experts
Shug.
posted on 11/11/03 at 06:25 PM Reply With Quote
I'm building a chassis at the moment and the materials so far, almost enough to complete it, have cost under £100. It's mig welded but would tig without problems and will probably outlast me.
Why bother?
yours, Pete.
type 907
posted on 11/11/03 at 07:25 PM Reply With Quote
Hi Digger, Welcome to the site.
U2U me with your email.
Fellow chemical plant fabricator. ( Paul G )
JohnN
posted on 11/11/03 at 07:52 PM Reply With Quote
Hi Digger,
I am building a chassis from 308 grade stainless box section, 1.5mm wall thickness, it may be more expensive, but properly TIG welded will not need paint for protection and will be stronger. And of course it looks good.
Only problem I've encountered so far is due to its greater thermal expansion. I suggest you practice doing very quick tack welds, as if you take your time it will deform as it cools. I haven't yet started fully welding the chassis up.......
I'm looking forward to panelling the sides and bottom with 0.9mm stainless sheet and "plug welding" instead of rivetting.
Stainless must be the choice for the process engineer!
JohnN
posted on 11/11/03 at 08:46 PM Reply With Quote
Just checked my receipts, its 304 grade stainless, not 308, the filler rods I'll eventually use are 308.
BTW I'm not using stainless for the wishbones, as they are critical suspension items, they are CDS tube as per book. Just had them powder coated, they look fantastic in black
JohnN
Digger Barnes
posted on 12/11/03 at 08:16 AM Reply With Quote
Hello all BTW no offence taken, my original post was a bit ambiguous.
I get a feeling that this forum may become my home over the next year or so.
mmm interesting I had not considered stainless for the side panels. Is there a weight penalty for doing this (I have not looked Kg/m2 for these thickness yet).
Good to that there does not appear to be any real reason why SS should not be used.
I agree it is not worth building the suspension from SS, I was just considering getting them chromed after construction. But hey I think that is still some way off in the mists of time yet. Although there are some stainless steels out there that have the same strength as high tensile steel, I am not sure of the grade without looking but 430 grade rings a bell some where in the dark depths of my mind.
VinceGledhill
posted on 12/11/03 at 09:11 AM Reply With Quote
I'll just re-itterate what was said before. Fully weld quickly. Don't give the stainless time to move.
Then again if your chassis moves and is about 5mm out when finished, what does it matter. As long as the wheels are all at 4 corners of an imaginary perfect oblong what does it matter. If the wheels are going in a straight line then the whole car will be.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Digger Barnes
posted on 12/11/03 at 09:19 AM Reply With Quote
Yep I have noticed that heat distortion can be a problem with stainless, especially with a slow hot weld like TIG.
So I suppose I will have to do a few time trials before I really get going at the beginning of next month.
JAG
posted on 12/11/03 at 10:16 AM Reply With Quote
I am a professional mechanical engineer.
My understanding of stainless steels is that they will work harden in use and be more prone to fractures in areas of high stress. The rate at which this hardening occurs depends upon the particular alloy being used.
High stress points will occur at any attachment point and at points throughout the chassis as road loads are applied.
I wouldn't copy the book chassis and make it from stainless steel (or Aluminium).
I would re-design the chassis using a finite element stress analysis package and ensure the stress distribution was kept within the limits of the stainless steel I was using. However this is outside of the capability of most of us.
Justin
kingr
posted on 12/11/03 at 11:33 AM Reply With Quote
One thing to bear in mind since you're building a BEC is that stainless is heavier (more dense) than mild and much heavier than ali. Granted, Jon Ison used a reasonable ammount of stainless for his locost (side panels and wishbones I believe), and general opinion was that it certainly didn't lack performance.
Another thing to consider is that there's potential for 304 to rust and given that some chassis members particularly at the rear are quite exposed to all the crud the road can throw at them, 304 might prove to be no better than well painted mild.
Kingr
Digger Barnes
posted on 12/11/03 at 01:18 PM Reply With Quote
mmm I have got a good deal of FEM/DEM experience and there are 3D models out there on the net so it should not be to difficult to import one of these into a package such as Ideas. But do you really think that this is necessary.
304 grade as you know is Austenitic, which is quite a ductile material compared with carbon steel. I agree work hardening is a particular problem especially when trying to machine these materials. But given the strengths below then it would appear to be stronger than the normal steels used for Locosts.
Carbon steel
Yield strength 165 MPa/in2
Tensile strength 415 MPa/in2
Elongation to failure 30% in a 2” test piece
304 grade stainless
Yield strength 241 MPa/in2
Tensile strength 565 Mpa/in2
Elongation to failure 60% in a 2” test piece
Is stainless much more dense than Carbon or mild steel?
Steel density @ 300K
Fe 7860Kg/m3
therefore assuming mild steel is to all intents pure Fe the density should be around 7860Kg/m3
304 grade stainless has a density 0f 7920 Kg/m3.
So yes stainless is more dense than mild, but only by 0.76% and the tube only comes in metric sizes i.e. 1.5mm wall thickness so the chassis should actually be ever so slightly lighter than for mild of wall thickness 16 gauge.
As to corrosion of 304, it is true that 304 does rust under certain conditions. We use allot of 304 on site. Rain and water do not seem to have a rusting effect, but chloride corrosion is defiantly a real problem. Oh well if I do decide to use this material then I will have to make sure that I keep it clean and don’t constantly drive round on wet salted winter roads.
The information that people are giving me here is great it has really made me think and I have had to pull a few books off the shelf to check things out. Great just the sort of input that helps me to come to a good final decision on the build materials.
P.S. one of the earlier posts mentioned not making suspension parts from stainless. On my trawls through the Perrys (the chemical engineers bible) I noticed there are a few very high strength SS’s that are stronger than high tensile steel, such as Almar 362, AM350, W, PH15-7Mo, PH14-8M0, Custom 450 and Custom 455. Although I would imagine these materials are probably extremely expensive
splitrivet
posted on 12/11/03 at 01:23 PM Reply With Quote
I agree with Pete and kingr apart from the unanswered questions of the stress effect on stainless why make your life more complicated.Im sure most of us agree that when your into the build proper you'll have more than enough problems to resolve without adding to em.
Bob
Alan B
posted on 12/11/03 at 01:42 PM Reply With Quote
Yep, me too...I design special purpose machinery and automation..We often use SS on food handling equipment.
Yes, I'd agree with all that...
And therein lies the problem.....as if it isn't hard enough to use FEA for a regular mild steel spaceframe just allowing for the the static and dynamic loadings, which are difficult to predict.......now you have all these cooling and shrinkage stress to predict.......
At the end of the day everyone has a free choice, that's why it's such fun....but IMO stick with mild steel...as has been said there are still loads of challenges beyond the frame...
JAG
posted on 12/11/03 at 03:53 PM Reply With Quote
Alan B we sing from the same hymn sheet then
and I fully agree with you - I bought a chassis in steel from Stuart Taylor. Mainly because I hope he has jigs and better welders than I can provide.
There are indeed plenty of other things to keep the old grey matter busy without re-designing the chassis to suit Stainless steel or Aluminium etc...
Justin
Alan B
posted on 12/11/03 at 04:04 PM Reply With Quote
Alan B we sing from the same hymn sheet then ...
Oh you don't want to hear me sing.....
No really you don't....
Hugh Paterson
posted on 12/11/03 at 09:23 PM Reply With Quote
Har har har, methinks I will build the Second car in stainless steel to prove all u doubters wrong, using 316L, I build towing points for tugs and workboats out of this stuff that tow upwards of 50 tons bollard pull and nuthins snapped yet in 20 years Anyone got any spare body armour to test it with just in case
Shug.
New Topic New Reply
