Author: Subject: q for all the brainiacs
oadamo
posted on 6/4/08 at 10:32 AM Reply With Quote
hi all iam trying to find out what gearbox and chain drive spocket sizes i need for this to push a load of 4 ton anyone have idea of what i would need.
adam
chriscook
posted on 6/4/08 at 10:34 AM Reply With Quote
Depends on torque/speed rating of motor, what the gearbox ratio is, how fast you want to push it, is the load on wheels/rails/nothing, uphill/downhill?
oadamo
posted on 6/4/08 at 10:42 AM Reply With Quote
its needs to go at about 3 mph and it will be free running until it pushs the load and its all on flat ground.
adam
Liam
posted on 6/4/08 at 12:05 PM Reply With Quote
Need to know rated speed of motor and gearbox ratio. At a guess though - if you wanna push 4 tonnes with an 800 W motor - i'd say you want the smallest damn sprocket you can get on there!
Liam
jono_misfit
posted on 6/4/08 at 02:44 PM Reply With Quote
Put a torque wrench on the hub nut of the wheel (if you can) and see how much the turn over torque is to move the 4 tonne load.
If you know the starting torque of the motor you could work out the sprocket sizes based on torque ratios.
