Author: Subject: Copper Pipes OK?
smart1275gt
posted on 6/4/08 at 02:54 PM Reply With Quote
Copper Pipes OK?
As a quick fix, will household copper pipes work on a car for coolant transfer pipes and bends, etc?
posted on 6/4/08 at 03:13 PM Reply With Quote
they will take the pressure and temp no probs.
posted on 6/4/08 at 03:18 PM Reply With Quote
As a quick fix?..... Copper plumbing is a permanent solution for most of our cooling systems.
Phil
Lars
THat's what I am using.
And I have seen a few other people do this.
posted on 6/4/08 at 03:22 PM Reply With Quote
If you don't want the copper look, you can even have it powder coated too......
Phil
indykid
posted on 6/4/08 at 04:07 PM Reply With Quote
if you use end feed fittings, it doesn't look quite so much like a central heating system i've found.
i still have a mix of solder ring and end feed though
tom
Danozeman
posted on 6/4/08 at 05:08 PM Reply With Quote
MIne will have som copper pipe in it when i get round to re doing it. You can use chromed pipe and compression fittings if u want an expensive way would look bling
Dan
smart1275gt
posted on 6/4/08 at 05:29 PM Reply With Quote
I didn't mean it as a quick fix, I meant a quick way of assembling the pipework. Love the powder coated look!
What pipe sizes are available? Can you get reducers and stuff?
[Edited on 6/4/08 by smart1275gt]
jlparsons
posted on 6/4/08 at 06:18 PM Reply With Quote
if you really wanted you could spray paint it aluminium wheel colour. Personally I don't care how it looks as long as it works ok! I guess it might be marginally heavier than other options ie plastic/silicon tubing?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
Mal
posted on 6/4/08 at 06:43 PM Reply With Quote
You can also have it zinc plated.
It comes out looking like chrome
plating.
posted on 6/4/08 at 07:02 PM Reply With Quote
at least 4 sizes
10 mm - micro bore - too samlly for ys
15 mm - standard water pipe
22 mm - larger pipe for boilers
> 22 mm - vern larger for big boilers, dunni what size.
reducers, elbows. joins, end caps etc. can be gotten cheaply from B&Q - plumbing section. aisle 25.
Stuart_B
posted on 6/4/08 at 07:06 PM Reply With Quote
I have plumb mine in 28mm copper pipe.
And i will be using chromed copper from the water pump to the carb.
stuart
