New Topic New Reply
Author: Subject: Assembling the bodywork
SyKaTurbo
posted on 14/4/08 at 01:57 PM Reply With Quote
I'm nearing the stage of attaching the Indys bodywork. I just wondered if there is any particular order is best to fit this in to ensure a good fit. Also, any tips or pointers to getting a good finish?
I'm presuming most jobs around the car can be done with the body attached to the car as its not that intrusive to the main components.
Ta
Simon
posted on 14/4/08 at 02:28 PM Reply With Quote
This is how I did it....
1. Fit side panels.
2. Fit scuttle so the rear (dashboard) edge lines up with where the side panels start to narrow.
3. Fit bonnet in alignment with scuttle.
4. Fit nose cone sligned with bonnet and side panels.
5. Fit rear panel which is difficult as it's slightly too wide for the car in practice.
6. Fit rear arches aligned with lower edge or side and rear panels.
7. Feck about for weeks bending and re-bending the wing stays and tryin to align the front cycle wings - not my favouritw part of the build
8. Stand back and congratulate self on producing something that now looks like a fully fledged car then jump in for some stationary "vroom-vroom" driving action
Kev99
posted on 14/4/08 at 02:55 PM Reply With Quote
Same as above for me too
Guinness
posted on 14/4/08 at 03:49 PM Reply With Quote
Third vote for that sequence.
Although I must have been lucky and managed to get my wing stays done just once!
Mike
RK
posted on 14/4/08 at 04:22 PM Reply With Quote
And in a related story:
Glue, screw or rivnut side panels?
Also, screw or rivnut brake and fuel line p-clips?
Can tabs for nose, scuttle and bonnet be rivetted onto chassis instead of welded?
roadrunner
posted on 14/4/08 at 06:32 PM Reply With Quote
If there was one panel i got wrong, it was the back panel, i fixed it first to the two short bars at the top just behind the rollover bar, i should have fixed it first on the bottom bar going round the back.
SyKaTurbo
posted on 15/4/08 at 07:32 AM Reply With Quote
Brilliant. Will hopefully have some pics of it to show after the weekend.
Oneone got good images of the fitting in there gallery so I can take a nosey.
Jonte
posted on 15/4/08 at 05:45 PM Reply With Quote
1. Fit side panels.
After the sidepanels I would fit the nose cone then trial fit the bonnet so the scuttle aligns good in length. But that´s me
Click it
New Topic New Reply
