bobs bangers
posted on 14/4/08 at 09:08 PM |
zx10r fuel return
Plumbing my ZX10R in and It looks like I might need a filterking or similar device ? How did the zx10R owners install theirs. Im not using a zx10 bike
pump. The engine is a 2007 model year. Any help and advice appreciated.
Regards
Bob
bigrich
posted on 14/4/08 at 09:16 PM |
Hi Bob
The zx10r doesnt have a return line. the stoch pump regulates inside the tank at approx 43psi.
If you using an external pump i would fit a FSE type regulator at the rear next to the pump/tank and just run one line to the front.
although being a hard up yorkshire man i went for a zx6r pump in the tank for 15 quid from the bay of E.
bigrich
posted on 14/4/08 at 09:20 PM |
You will need something similar to this
http://www.fuelsystem.co.uk/pbv.htm
Rich
PAUL FISHER
posted on 14/4/08 at 09:21 PM |
To be honest Bob your better off using the original bike pump,and mount it in the base of the fuel tank,it has a built in regulator,built in fuel
level warning sensor,and you only have to run a single fuel pipe up to the engine,no return pipe required,also you no its going to run at the correct
pressure,43psi by the way,if you do choose your option
Wish I could type faster
bobs bangers
posted on 14/4/08 at 09:33 PM |
Thanks guys . I will need to look into this !! I just fitted the sender supplied by mnr. This is where it gets a bit too technical for me.
Regards
Bob
paulmw
posted on 15/4/08 at 07:29 AM |
As above. I had MK engineering fit the ZX10r pump into the tank when he made it. Only one fuel line required and a simple install
Paul
bobs bangers
posted on 15/4/08 at 07:08 PM |
Thanks Rich.Paul Fisher and Paul M W. I was all set to rip out the tank and revert to bike equipment. However Malc @ yorkshire engines has come up
with a plan. Would you believe that a 1979 opel manta fuel pressure regulator will do the job. Its a bosch part so should be reasonably available.
Roughly £37
Thanks again Guys
