Dickyboy
posted on 15/4/08 at 08:20 PM |
Oxy/propane welders
Can anyone relate experience of oxy/propane mini welders, using disposable gas bottles? do they work? how long do bottles last (£16 a pop!)?
Am tidying up the chassis on a part built acquisition and having problems where there is a small gap between tubes and weld blows through, using a
filler rod may help I hope!
trikerneil
posted on 15/4/08 at 09:14 PM |
I have an oxy/mapps gas set which I'll admit I haven't used for years but IIRC it was always a b*gger to get going and was a bit like
welding with a dirty nozzle.
Once set up and running it was OK
HTH
Neil
ACE Cafe - Just say No.
Michael
posted on 15/4/08 at 09:25 PM |
Id like to know the same as the large rental bottles are to expensive.
paulf
posted on 15/4/08 at 09:50 PM |
I tried one years ago and the oxygen lasted about 15 mins so very expensive to use.I think the oxygen in them is actually nitrous oxide so that may
be a cheaper way if you could get a suitable bottle and have it filled.
Paul
Mark Allanson
posted on 15/4/08 at 09:55 PM |
Fine for braising, not hot enough for welding
caber
posted on 16/4/08 at 08:33 AM |
Forget proppane except for cutting and use a prper propane nozzle. You can get big bottles fro Air products on deposit but they only charge you hire
by the day so if you take them back between jobs it is much cheaper than the BOC annual rip off! If you return BOC bottles they charge you up to the
end of the month.
Caber
posted on 16/4/08 at 10:29 AM |
Propane flame carbonises metal, turns it to a crumbly coke like mess no good for welding. Mapp gas will braze without adding oxygen. There are some
that use something called turbo gas but I think this is just mapp gas and oxy, they are hotter than propane.
Like this and they are not cheap.
