Author: Subject: cable
jimhammer
posted on 7/5/08 at 04:26 PM Reply With Quote
cable
need a couple of bolts with hole drilled through to retain clutch and throttle cables, solderless nipples not strong enough.
Anyone know if these are available online?
(yeah I know I could make my own, but after the third drill bit I've 'ad enough!)
thanks
jim
cryoman1965
posted on 7/5/08 at 04:27 PM Reply With Quote
There maybe someone on here with a Lathe that could make them for you.
Sorry i dont have one .
N
posted on 7/5/08 at 04:47 PM Reply With Quote
what about soldered nipples then?
clean the cable end, slapy it out, some plumber solder and job done.
VWP sell he cable and nipples - hundreds of thousands of BSAs used this without problem.
but if you insist on drilling bolts - not easy as you have found out, then what about using the cable adjusters? bit more pricey unfortunately.
smart51
posted on 7/5/08 at 05:37 PM Reply With Quote
You could just drill through a couple of bolts. I have. File a flat on the bolt by the head and mark with a centre punch. Hold the bolt in a vice and drill.
