New Topic New Reply
Author: Subject: headlamp mounts/design please
bpgoa
posted on 11/5/08 at 11:07 PM Reply With Quote
anyone know where to get hold of approx 40mm x 15mm rounded edge, box section stuff to use as the headlamp extension brackets (about 500mm should do)...
saying that does anyone know how far from the front of the Locost chassis I should mount them and how far out they should be??
Ade.
On and On the River flows... We the Undertow
Simon
posted on 12/5/08 at 12:55 AM Reply With Quote
Go to B&Q and get some box section. You'll probably want to mount them above the spring tops - that way they won't get hit every time you turn the wheel
Simon
bpgoa
posted on 12/5/08 at 06:23 AM Reply With Quote
I've got box section... I'm after the stuff with the rounded edge.
Any clue where to get a short piece?
mad4x4
posted on 12/5/08 at 12:04 PM Reply With Quote
I used Round tube and welded a plate on the end to allow it to bolt down to the chassis. (Guess you could just bolt through without the flat plate). Then at the other end (headlamp) just closed the end with the vice and filed (ground) it smooth and round. That bit was then drilled to mount the headlamp.
Why can't you take a sanding pad for a grinder and round the edge of the box section you have?
There should be plenty material to do this as this will not be structural only a bracket.
Mine Sit about 50mm forward of the back of the nose cone. and stick out far enough to allow center of headlamp to meet SVA spacing distance as per SVA Manual.
Note you may need to put extensions on you inidcators, to meet minimum spacing etc. depending where you mount them
[Edited on 12/505/08 by mad4x4]
Scot's do it better in Kilts.
posted on 12/5/08 at 12:49 PM Reply With Quote
I think what he's after is some of the oval section tube that most manufacturer's make their wishbones from
Might be best to contact MK, MNR, MAC1 and the like and see if they'll sell you an off cut.
Alternatively, IIRC I only paid £20 for a finished headlamp bar from MK made from the same stuff with nice round ends welded on for mounting the lamps on.
Michael
posted on 12/5/08 at 09:16 PM Reply With Quote
I have made mine using black metal electrical conduate. You know the stuff you see in sites that have wall sockets surface mounted.
Then have two plates made from two in box section with bottom cut off and one face radiused to match outside diameter of conduate and the headlight bolts to that.
Mine sits on the top rail and bolts to that using two plates made of 3/4 box with top face removed and sides removed.
bpgoa
posted on 13/5/08 at 07:35 AM Reply With Quote
nick is right... i'm just after the tubes ... and the distance between the centre of the headlights/ heights etc..
i know it's in the sva book but i don't have it
Macbeast
posted on 13/5/08 at 08:19 AM Reply With Quote
Here we go - hopefully
Front lighting
Front lighting
[Edited on 13/5/08 by Macbeast]
bpgoa
posted on 13/5/08 at 06:40 PM Reply With Quote
Hey thanks... don't suppose you have the same pic for the rear lights
also does anyone know where to get the tube stuff from
mistergrumpy
posted on 13/5/08 at 06:45 PM Reply With Quote
Here
bpgoa
posted on 13/5/08 at 07:48 PM Reply With Quote
Thanks guys.... That'll save some digging around. (and the angle grinder...)
Anyone know where to get the tube from???
posted on 14/5/08 at 09:26 PM Reply With Quote
MK will almost certainly sell you some
Taz Surfleet
posted on 15/5/08 at 11:48 AM Reply With Quote
You could always just flatten some
round section off with the vice not like its a long length required!!
Guinness
posted on 15/5/08 at 09:21 PM Reply With Quote
Allegedly certain shopping trolleys have a nicely profiled section to them.
Not that I would condone such activities, but if you see one in the scrapyard
Mike
bpgoa
posted on 15/5/08 at 11:18 PM Reply With Quote
mmm... I feel the need for some retail therapy ...
New Topic New Reply
