Author: Subject: What do you get when you cut open a damper
Miks15
posted on 25/5/08 at 11:30 AM Reply With Quote
Basically as title.
I need to start chopping them up to make my front uprights useable. QUestion is what am i to expect when i cut it open?
Oil going everywhere? Is it pressurized?
Cheer
posted on 25/5/08 at 11:31 AM Reply With Quote
It very much depends on what type of damper it is.....
Miks15
posted on 25/5/08 at 11:34 AM Reply With Quote
Ok well worst case scenario?
b184
posted on 25/5/08 at 11:40 AM Reply With Quote
Gas or oil escape
I would possible start off with hack saw very carefully
Which model bmw is your doner?
[Edited on 25/5/08 by b184]
Miks15
posted on 25/5/08 at 11:44 AM Reply With Quote
Its an E36, ill take pictures of the finished product to help inpsire you if youd like b184?
Volvorsport
posted on 25/5/08 at 11:50 AM Reply With Quote
arent they inserts in the strut tube ?
if its 50mm tube just buy some and start from there .
www.dbsmotorsport.co.uk
getting dirty under a bus
b184
posted on 25/5/08 at 11:52 AM Reply With Quote
Have you seen the front hub mods on the haynes forum, I will try and find the post
Miks15
posted on 25/5/08 at 12:21 PM Reply With Quote
no its not just an insert like a macpherson, the damper is bolted onto the upright.
Ive seen that mod b184 but ive had ago and the surfaces are exactly easy to line up so i think this is the best way.
And the answer... Pressurized oil shot up about 2 m glad i wore some goggles just in case
mark chandler
posted on 25/5/08 at 06:42 PM Reply With Quote
If they are gas/oil this is what you get, under pressure so hold upright, drill a small hole at the top to vent the pressure away.
Its now an oil only damper, so just get a hacksaw and cut around where you want the cap welded on, it will bleed oil but only a pint or so.
Cut around the outside as the middle rod will be quite hard, 2 minute job.
NB save the rod, useful for poking things and making nice chrome levers etc.
Regards Mark
