dozracing
posted on 1/12/03 at 01:06 PM |
USP - Adjustable camber
Hi all,
As an additional tasty feature for the new kit, we will be doing an easily adjustable top wishbone so camber can be changed without removing the top
ball joint.
Kind regards,
Darren
okey dokey
posted on 15/1/04 at 07:26 PM |
Easy adjustable top wishbone
So much better and looks very trick
dozracing
posted on 21/2/04 at 03:46 PM |
Attached is a pic of the camber adjuster system.
The steel tube shown is cut to short for clarity. In reality this is longer than the gold threaded adjuster. The steel part replaces the normal book
M18 threaded boss.
RogerM
posted on 24/2/05 at 07:06 PM |
Is this availble for incorperating into some home built special wishbones, not a locost so no off the shelf bolt on bones avaialble, anyway, I like to
do my own geometry!
dozracing
posted on 25/2/05 at 05:31 PM |
Hi Roger,
Yes you canbuy this off the shelf for your special build.
Kind regards,
Darren
